Can’t say, because it won’t install.
I have to hit the “Check for update” link several times to get it to acknowledge there is a new version. When I tell it to do the update, the installer says 1.7.2 is already installed (which it is).
Maybe an issue with the install URL?
Shoot Glen I don’t know it came right thru. Perhaps they are working on it and went off line for a bit
I just hit check updates and it bounced right back that 1.8 is latest
The addition of the folder folder structure is very nice. My compliments.
Is it just me that the titles remain truncated?
In any case, it’s consistent. As far as I move the bar to the left, the text is truncated. And after scrolling, the titles will be refreshed again.
Yes. Windows 11 actually (I’m brave).
It seems to be working now. Update in progress…
Second edit: Yep, it updated.
Everything appears to be working fine, but since I don’t have any local files, this release doesn’t really have any updates for me. I do wish the “Other minor fixes” part of the release notes provide at least some details on what was “fixed”.
All is well.
Hi Alain,
On my computer (NUC Windows, 4k TV screen) it looks OK and it is very workable:
I also tried it on my 27 inch 1080p computer monitor and that works fine too.
What kind of screen resolution do you use? Or could it be a specific Mac issue?
@AndyLubke
I saw that some screen capture look good and other are like mine. Effectively it could be a MAC only problem. I am waiting for @Antoine answer.
