Hi… I got the upgrade automatically onto Windows 11. Running kernel streaming. DAC reached by uPnP.
Now setting the volume control increment - eg 0.1dB - doesn’t actually change volume increments by that. When the +/- is clicked, often the dB level doesn’t change. If rapidly clicked a few times, then the dB level jumps to a new level that is not the same as the (nbr of clicks x volume control increment) that it should be.
Hello @iainhanderson ,
Can you change this setting and put 1 dB increment instead?
