Audirvana 3.5.43
SoX to DSD512 with filter type B 7th order
SW volume control: ON
Sync list: 0 folders
Library database path: C:\Users\jeanf\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 1024MB
Local Audio Engine:ASIO 2 driver version 2
T+A PDP3000 USB ASIO
Model UID:T+A PDP3000 USB ASIO
Device: 2ch 8bits Integer, 2 bytes per frame 22579.2kHz
Active Sample Rate: 22579.2kHz
Sample rate limitation: 96kHz
T+A PDP3000 USB ASIO Manufacturer:
Model UID:T+A PDP3000 USB ASIO UID:T+A PDP3000 USB ASIO
13 available sample rates up to 45158400Hz
5644800
11289600
22579200
45158400
DSD capability: Raw DSD (MSB)
2 ch DSD 8bit big endian in 8bit chunk 45158.4kHz
Device #0: Combo384 ASIO 1.03 Manufacturer: Model UID: Combo384 ASIO 1.03 UID: Combo384 ASIO 1.03
Device #1: T+A PDP3000 USB ASIO Manufacturer: Model UID: T+A PDP3000 USB ASIO UID: T+A PDP3000 USB ASIO
