Hello,
I updated to 3.1 and I get a crash about three seconds after the app is opened.
Here is the crash report:
Running the latest OS.
Any suggestions?
Hello,
Any suggestions?
Try Updating to 3.1.1 and see
Thank you for the suggestion. I downloaded the trial version of 3.1.1 - Upon opening I got the same result - it lasted about three seconds before it crashed -
this is not the crash report but just a picture of the beginning of the crash report…
This is a crash in the MQA device detection library.
Do you have a MQA DAC?
If not you may want to disable the MQA devices automated detection.
BTW, can you send me the full text of the crash report (by PM or email)?
If you can’t disable this option as it crashes at startup, you can delete the preferences file: com.audirvana.audirvana-plus.plist
It is located in ~/Library/Preferences
To access ~/Library with the Finder, you can use its Go menu while pressing the option (or alt) key. This reveals the Library command in this Go menu.
Be sure to reboot before launching Audirvana Plus again.
Hi,
I’m running a registered 3.1.1 version having updated last night. Was please to see my various Squeezeboxes appearing in the Select list so chose my Touch and A3+ crashed immediatley. Restart fails and I’m stuck in a crash loop. Only way out seems to be to install v3.0 and the apply the 3.1.1 update and avoid selecting anything other than my DAC’s.
There’s no file in Library/Preferences to remove.
Happy to provide the crash report if that helps.
Here’s a snippet of the stack trace…
Process: Audirvana Plus [846]
Path: /Applications/Audirvana Plus.app/Contents/MacOS/Audirvana Plus
Identifier: com.audirvana.Audirvana-Plus
Version: 3.1.1 (3121)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: Audirvana Plus [846]
User ID: 502
Date/Time: 2017-08-26 13:59:33.774 +0100
OS Version: Mac OS X 10.12.6 (16G29)
Report Version: 12
Anonymous UUID: 22D8F061-6B90-03C1-5776-0BE4C28E79C0
Sleep/Wake UUID: CC2D7E61-E934-46FF-BAAD-F743C07B9029
Time Awake Since Boot: 9000 seconds
Time Since Wake: 1500 seconds
System Integrity Protection: enabled
Crashed Thread: 24 Dispatch queue: com.apple.root.default-qos
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Application Specific Information:
Assertion failed: (e == 0), function unlock, file /BuildRoot/Library/Caches/com.apple.xbs/Sources/libcxx/libcxx-307.5/src/mutex.cpp, line 102.
NB/I’m not using MQA option
it is in your Home Folder… Library… for the preferences… not the System Library or the main Library
Thanks for the help - the “secret” solution was to delete Audirvana prefs from my home library, re-enter my code, and I’m back up and running.
Thanks for steer re Library…obvious really.
Ok, zapped the pref file, rebooted, entered key and up and running again.
However, it still doesn’t let me choose DSD512 and it still crashes instantly when I choose any upnp device listed so no real progress.
For DSD512… read this guy comment:
https://www.computeraudiophile.com/forums/topic/27992-macmini-setup-for-dsd256-dsd512/?do=findComment&comment=541092
for the other point, i just use a direct connection from Mac Mini to USB hard drive already APFS formatted for High Sierra coming. Can’t help
With 3.1.1 crashes, del .plist from ~/Library/Preferences helped me too…
update. but for two hours. next deletion with no any effect
Can you update to 3.1.2 I’ve just released, and try again?
it’s works.
Hi, I have a problem with 3.1.2 version, I find my device on audio system ( Micromega M one ) but player start only one second and stop with noise and no music. it is the same with qobuz but with no noise. And now, I don’t find anymore my device in airplay.
I didn’t find file: com.audirvana.audirvana-plus.plist, I find only file with com.apple…plist. Is someone can help me please ?
trash com.audirvana.Audirvana-Plus.plist in that folder (those are A+ software preferences)
I found this folder and trash it, reboot the computer then re-enter the key for audirvana but I have got the same problem noise and no music…
If you want you can try starting like new… and see if it cure your bug:
maybe you have try also to unplug your DAC, stop A+ restart MAC, Restart A+, plug your DAC…
Start fresh A+ by deleting those files…
If you have Playlists that are important export them first to desktop and
save them in a folder… when A+ is reset, you can re-import them back.
sadly to this day, the folders they were in is not back, you have to do it again…
Before doing this, maybe you should not connect after deleting those files to Roon or others…
Install A+ alone with your database… if working, log to Roon or else after
Starting for new A+:
Trash All the files in that folder from A+ (that folder install SysOptimizer)
Trash All the files in that folder from A+ (SystemOptimizer and prefs files)
Trash All the files in that folder (that is your database of music, back it up!)
Go to User… Home Folder… Library… Caches… com.audirvana.Audirvana-Plus
trash the files in that folder
Restart MAC. This will reset pretty much Audirvana like new.
When choosing library at first it will sync in top right main window under the logo…
LET IT GO, even better don’t try to adjust windows or edit files, even playing music
while it is not finished… you’ll see the progress bar going… Could be long the first time
depending on how large your library is, and MAC is fast or not…
