Hi Damien,
Thanks for your quick reply. Here’s the debug info:
Audirvana 3.5.3
AUTO: D:\musik
Library database path: C:\Users\HuHa!\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Qobuz: Connected as Qobuz Hi-Fi
Max. memory for audio buffers: 15546MB
Local Audio Engine:WASAPI
Main Out 1/2 (Studio 26c)
Model UID:Main Out 1/2 (Studio 26c)
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{e2a7ff6e-c248-4ce7-bdd6-c8a61a861efb}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device: 2ch 24bits Integer, 8 bytes per frame 96kHz
Active Sample Rate: 96kHz
Main Out 1/2 (Studio 26c) Manufacturer:
Model UID:Main Out 1/2 (Studio 26c) UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{e2a7ff6e-c248-4ce7-bdd6-c8a61a861efb}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Simple stereo device: No
Device #0: Main Out 1/2 (Studio 26c) Manufacturer: Model UID: Main Out 1/2 (Studio 26c) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{e2a7ff6e-c248-4ce7-bdd6-c8a61a861efb}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #1: Line Out 3/4 (Studio 26c) Manufacturer: Model UID: Line Out 3/4 (Studio 26c) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{a1ea71b3-16eb-4dc1-a274-6646e1e075f3}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
