I will soon have to switch audio solutions - A+ is simply too buggy and useless to enjoy music. Now the issue appears with my headphones as connected to the EarMen Sparrow:
macOS 10.14.6 with 24576MB RAM
Registered to XXXXX
AUTO: /Volumes/LaCie 5Big RAID 5/Other Music
iTunes/Music library synchronization: last synchronized on Fri Feb 7 23:07:20 2020
Library database path: /Users/XXXXX/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
HRA-Streaming: Connected as SUBSCRIPTION
Direct Mode audio path, buffer I/O frame size: 4096
Max. memory for audio buffers: 13056MB
Integer mode: Disabled
EarMen Sparrow
Model UID:EarMen Sparrow:0495:1044
UID:AppleUSBAudioEngine:Auris:EarMen Sparrow:0:1
Device: 2ch Non-mixable linear PCM Interleaved 24bits little endian Signed Integer, 6 bytes per frame 96kHz
Hog Mode is on
ID 0x27 EarMen Sparrow Manufacturer:Auris
Model UID:EarMen Sparrow:0495:1044 UID:AppleUSBAudioEngine:Auris:EarMen Sparrow:0:1
Stream ID 0x28 2 channels starting at 1
40 virtual formats:
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 768kHz
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 705.6kHz
60 physical formats
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer 768kHz
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer 705.6kHz
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer 384kHz
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer 352.8kHz
2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 768kHz
Device #0: ID 0x31 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:130 UID: AppleHDAEngineOutput:1F,3,0,1,2:0
Device #1: ID 0x27 EarMen Sparrow Manufacturer: Auris Model UID: EarMen Sparrow:0495:1044 UID: AppleUSBAudioEngine:Auris:EarMen Sparrow:0:1
UPnP devices found : 1
Device #0: ID 0x0 UBP-X800 UID: uuid:00000000-0000-1010-8000-045d4b70c14a Location: http://192.168.1.5:52323/dmr.xml
