Now, as the synch started, the application is barely responsive, like it was before.
If I click at anything, the beach ball starts spinning for at least a minute.
And you have nothing more in Terminal?
Yes, there are new lines in the Terminal:
Invalid PacketToFrame conversion
There are more of them, now:
Ok, i will talk about this with Damien and come back to you.
Meanwhile, I will leave Origin synching.
And more new lines:
2022-04-21 17:51:09.858 Audirvana Origin[38672:2041864] CueSheet loader: incorrect INDEX,TRACK,FILE order, discarding damaged cue sheet file /Volumes/Rock & Jazz 18 To/Rock FLAC Library/Albert King/1962 Albert King - The Big Blues (2016 Soul Jam 600884)/The Big Blues.cue
2022-04-21 17:51:15.219 Audirvana Origin[38672:2041864] CueSheet loader: incorrect INDEX,TRACK,FILE order, discarding damaged cue sheet file /Volumes/Rock & Jazz 18 To/Rock FLAC Library/Albert King/1962 Albert King - The Big Blues (2016 Soul Jam 600884)/The Big Blues.cue
2022-04-21 17:51:15.450 Audirvana Origin[38672:2041864] CueSheet loader: incorrect FILE,TRACK,INDEX order, discarding damaged cue sheet file /Volumes/Rock & Jazz 18 To/Rock FLAC Library/Albert King/1968 Albert King - Live Wire-Blues Power (1989 US MFS MFCD 838)/Live Wire/Blues Power.cue
2022-04-21 17:51:15.454 Audirvana Origin[38672:2041864] CueSheet loader: incorrect FILE,TRACK,INDEX order, discarding damaged cue sheet file /Volumes/Rock & Jazz 18 To/Rock FLAC Library/Albert King/1968 Albert King - Live Wire-Blues Power (1989 US MFS MFCD 838)/Live Wire/Blues Power.cue
2022-04-21 17:51:18.855 Audirvana Origin[38672:2041864] CueSheet loader: incorrect FILE,TRACK,INDEX order, discarding damaged cue sheet file /Volumes/Rock & Jazz 18 To/Rock FLAC Library/Albert King/1969 Albert King - Years Gone By (1989 US Stax SCD-8522-2)/Years Gone By.cue
2022-04-21 17:51:21.673 Audirvana Origin[38672:2041864] CueSheet loader: incorrect FILE,TRACK,INDEX order, discarding damaged cue sheet file /Volumes/Rock & Jazz 18 To/Rock FLAC Library/Albert King/1974 Albert King - I Wanna Get Funky (1990 Stax SCD-8536-2)/I Wanna Get Funky.cue
2022-04-21 17:51:23.047 Audirvana Origin[38672:2041864] CueSheet loader: incorrect FILE,TRACK,INDEX order, discarding damaged cue sheet file /Volumes/Rock & Jazz 18 To/Rock FLAC Library/Albert King/1974 Albert King - I Wanna Get Funky (1990 Stax SCD-8536-2)/I Wanna Get Funky.cue
2022-04-21 17:51:24.502 Audirvana Origin[38672:2041864] CueSheet loader: incorrect FILE,TRACK,INDEX order, discarding damaged cue sheet file /Volumes/Rock & Jazz 18 To/Rock FLAC Library/Albert King/1974 Albert King - I Wanna Get Funky (1990 Stax SCD-8536-2)/I Wanna Get Funky_fix.cue
2022-04-21 17:51:26.469 Audirvana Origin[38672:2041864] CueSheet loader: incorrect FILE,TRACK,INDEX order, discarding damaged cue sheet file /Volumes/Rock & Jazz 18 To/Rock FLAC Library/Albert King/1974 Albert King - I Wanna Get Funky (1990 Stax SCD-8536-2)/I Wanna Get Funky_fix.cue
2022-04-21 17:51:28.839 Audirvana Origin[38672:2041864] CueSheet loader: incorrect FILE,TRACK,INDEX order, discarding damaged cue sheet file /Volumes/Rock & Jazz 18 To/Rock FLAC Library/Albert King/1976 Albert King - Albert (1988 France CD CHARLY 103)/Albert.cue
2022-04-21 17:51:30.376 Audirvana Origin[38672:2041864] CueSheet loader: incorrect FILE,TRACK,INDEX order, discarding damaged cue sheet file /Volumes/Rock & Jazz 18 To/Rock FLAC Library/Albert King/1976 Albert King - Albert (1988 France CD CHARLY 103)/Albert.cue
2022-04-21 17:51:31.844 Audirvana Origin[38672:2041864] CueSheet loader: incorrect FILE,TRACK,INDEX order, discarding damaged cue sheet file /Volumes/Rock & Jazz 18 To/Rock FLAC Library/Albert King/1977 Albert King - Live (1989 US Rhino R2 71622)/Albert King - Live.cue
2022-04-21 17:51:33.129 Audirvana Origin[38672:2041864] CueSheet loader: incorrect FILE,TRACK,INDEX order, discarding damaged cue sheet file /Volumes/Rock & Jazz 18 To/Rock FLAC Library/Albert King/1977 Albert King - Live (1989 US Rhino R2 71622)/Albert King - Live.cue
2022-04-21 17:51:33.448 Audirvana Origin[38672:2041864] CueSheet loader: incorrect FILE,TRACK,INDEX order, discarding damaged cue sheet file /Volumes/Rock & Jazz 18 To/Rock FLAC Library/Albert King/1977 Albert King - The Blues Don’t Change (1998 Limited Edition PN-150)/The Blues Don’t Change.cue
2022-04-21 17:51:39.549 Audirvana Origin[38672:2041864] CueSheet loader: incorrect FILE,TRACK,INDEX order, discarding damaged cue sheet file /Volumes/Rock & Jazz 18 To/Rock FLAC Library/Albert King/1978 Albert King - New Orleans Heat (1989 US Tomato R2-70699)/New Orleans Heat.cue
Ok, the issue is coming from your cue sheet files:
Have you made any change in those files?
I kept the cue sheet file inside the folder of some of my albums, but the files are separated file tracks, and are not grouped as a disc image of the CD.
This is what I have for this album:
Ok, I will send it to you.
I sent you the file.
I got it, will review it as soon as possible.
Hello @Antoine ,
Four days passed, and for the second weekend, I was unable to use Origin.
Actually, since the beginning of the trial, it worked properly only for two days.
The remaining of the time it was unresponsive and unusable, stuck in its endless synching.
All the other players that I have synched my albums, despite the cue sheet files, without any problem.
Even Audirvana 3.5 synchs them without an issue at all.
Only Origin has this issue.
Any idea what can I do about it?
Does those players also support cue sheets?
I found time to open your cue sheets last Friday but I will take a deeper look at it today if I find the time.
Yes, JRiver for instance.
Based on what I can see in your cue sheet, it seems there is something wrong about index in it:
REM GENRE Blues
REM DATE 1977
REM DISCID 8E0A220B
REM COMMENT “ExactAudioCopy v1.1”
PERFORMER “Albert King”
TITLE “The Blues Don’t Change”
FILE “01 The Blues Don’t Change.wav” WAVE
TRACK 01 AUDIO
INDEX 01 00:00:00
TRACK 02 AUDIO
TITLE “I’m Doing Fine”
INDEX 00 05:26:17
FILE “02 I’m Doing Fine.wav” WAVE
INDEX 01 00:00:00
TRACK 03 AUDIO
TITLE “Nice To Be Nice (Ain’t That Nice)”
INDEX 00 03:49:50
FILE “03 Nice To Be Nice (Ain’t That Nice).wav” WAVE
INDEX 01 00:00:00
TRACK 04 AUDIO
TITLE “Oh, Pretty Woman”
INDEX 00 02:59:72
FILE “04 Oh, Pretty Woman.wav” WAVE
INDEX 01 00:00:00
TRACK 05 AUDIO
TITLE “King Of Kings”
INDEX 00 04:43:20
FILE “05 King Of Kings.wav” WAVE
INDEX 01 00:00:00
TRACK 06 AUDIO
TITLE “Feel The Need”
INDEX 00 03:26:35
FILE “06 Feel The Need.wav” WAVE
INDEX 01 00:00:00
TRACK 07 AUDIO
TITLE “Firing Line (I Don’t Play With Your Woman, You Don’t Play With Mine)”
INDEX 00 03:28:20
FILE “07 Firing Line (I Don’t Play With Your Woman, You Don’t Play With Mine).wav” WAVE
INDEX 01 00:00:00
TRACK 08 AUDIO
TITLE “The Pinch Paid Off (Part 1)”
INDEX 00 03:42:25
FILE “08 The Pinch Paid Off (Part 1).wav” WAVE
INDEX 01 00:00:00
TRACK 09 AUDIO
TITLE “The Pinch Paid Off (Part 2)”
INDEX 00 03:39:70
FILE “09 The Pinch Paid Off (Part 2).wav” WAVE
INDEX 01 00:00:00
TRACK 10 AUDIO
TITLE “I Can’t Stand The Rain”
INDEX 00 04:48:05
FILE “10 I Can’t Stand The Rain.wav” WAVE
INDEX 01 00:00:00
TRACK 11 AUDIO
TITLE “Ain’t It Beautiful”
INDEX 00 02:50:37
FILE “11 Ain’t It Beautiful.wav” WAVE
INDEX 01 00:00:00
The INDEX 00 is not required and the INDEX 01 you have are not right, INDEX 01 is required and denotes the start of the track. You then need to change them so you should not have this error anymore. We will do a workaround for it in the next update of Audirvāna Studio/Origin but please keep in mind that if your cue sheet is properly made, it should not happen. A proper example can be found here:
Hello @Antoine ,
Thank you for taking the time to check this issue.
I understand that this CUE sheet is erroneous, and that others CUE sheets in the folder, with which Origin synchs endlessly, may be erroneous as well.
Though I can destroy this CUE sheet that is not necessary, since the tracks of the album are split, it will be impossible for me to identify the other erroneous CUE sheets.
This is a good thing, and I’m looking forward to this update.
Please let me know when it’s done.
Origin should not become unusable, it encounters an error in a CUE sheet file.
As I told you a few days ago, the other players on my Mac and my PC, who do read CUE sheet files, including Audirvana 3.5, work completely normally with the albums that are stored in the folder on which Origin gets stuck.
