A+ v3.2.2 (3122) Crashing
Hi.
Has anyone installed the latest version of A+ and found it crashing?
I cannot remember having an issue with the server crashing - at least 3 times since installing today.
The applications completely closes and the Apple Diag appears… Leaves the Remote A+ hanging - obviously.
Can send my Debug if you want.
Simply - Running 3.2.2 on MBPro 13" 2016 with High Sierra 10.13.2, to Oppo Sonica Dac
David
Looking through the Apple Log:
com.apple.xpc.launchd[1] (com.audirvana.Audirvana-Plus.3880[1076]): Service exited due to signal: Segmentation fault: 11 sent by exc handler[0]
I am having a really bad day with this latest update too. Numerous crashes throughout the time I was using it. Some AIFF files would refuse to play and Audirvana crashes on each relaunch. Files were tested on Quicktime playback and it does not have any issue.
Prior to updating the software, everything performed as it should.
After Disk Permission Repair, Audirvana Plus V3.2.3 had stopped crashing. Will update result after a longer period of useage. Fingers Crossed
Update… The App still crashes when DSD mode is selected. Sigh :confused:
@damien, any chance of rowing back the version to V3.2.1?
https://audirvana.com/delivery/AudirvanaPlus_3.2.1.dmg
