(Replace this first paragraph with a brief description of your new category. This guidance will appear in the category selection area, so try to keep it below 200 characters.)
Use the following paragraphs for a longer description, or to establish category guidelines or rules:
Why should people use this category? What is it for?
How exactly is this different than the other categories we already have?
What should topics in this category generally contain?
Do we need this category? Can we merge with another category, or subcategory?
Bug??
Recently purchased Audirvana and love it, using it mostly with Tidal and RME ADI 2 DAC.
I have what seems to be a small bug - in Tidal, in My Music, in Tracks (a fairly long list) when scrolling down the list using the scrolling bar on the right, when I get down to the bottom of the list all the titles start jumping about and the list becomes unusable. It is therefore impossible to select the last item on the list. I have to come out of the window and back in again.
Using windows 10 on a laptop.
Does anyone else have this problem and can it be fixed?
