Hi @Damien3,
Quite often I add a new playlist in Tidal and then want to use it in Audirvana. On the Windows app you can update the list of playlists using the “Add TIDAL Playlist” option.
However, I generally don’t use the desktop app. Would it be possible to include an “Add TIDAL Playlist” option on the Audirvana Remote for iOS and iPadOS?
Zane
