L’ampli tout en un Advance MyConnect 60 est il compatible avec Audirvāna ? Apparemment il supporte le DLNA.
Voici la documentation : https://www.advanceparis.com/fr/produit/myconnect-60/
I can’t tell you the answer. It depends how standardized the device’s UPnP/DLNA software is. Many manufacturers do not adhere closely to the standard and this can cause problems.
But this is only my limited knowledge. Perhaps someone else knows more and can provide more help.
