Hi, have downloaded the trial version of Audirvana as per details below. Impressed with the sound quality, but can not get Music Integrated Mode to work with airplay. Track will start playing on both the iMac and smart TV, but will only continue on the iMac; output on TV is strange, the track will play for about 30 seconds and then go back to the start of the song and repeat for the thirty seconds or so and then do the same again.
Any suggestions gratefully accepted.
Thanks for your help.
macOS 10.15.7 with 8192MB RAM
AUTO: /Volumes/Elements SE/iTunes/iTunes Media/Music
Library database path: /Users/davidwhittaker/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Exclusive access: Disabled
AirPlay
Model UID:81c14254-891e-4977-8dd9-15702eab6266-16496590160355-Audio
ID 0x29 Built-in Output Manufacturer:Apple Inc.
Model UID:AppleHDA:7 UID:AppleHDAEngineOutput:1B,0,1,2:0
4 virtual formats:
16 physical formats
Local devices found : 3
Device #0: ID 0x29 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:7 UID: AppleHDAEngineOutput:1B,0,1,2:0
Device #1: ID 0xc5 Soundflower (2ch) Manufacturer: ma++ ingalls for Cycling '74 Model UID: com_cycling74_driver_SoundflowerDevice:Soundflower UID: SoundflowerEngine:0
Device #2: ID 0x3e Soundflower (64ch) Manufacturer: ma++ ingalls for Cycling '74 Model UID: com_cycling74_driver_SoundflowerDevice:Soundflower UID: SoundflowerEngine:1
UPnP devices found : 1
Device #0: ID 0x0 Living Room TV UID: uuid:23456789-1234-1010-8000-38184C9FAF00 Location: http://192.168.15.10:52323/MediaRenderer.xml
