Album Track List Double Up
Updated Origin to 2.5.21 and now my album tracks have doubled up. I’ve checked database integrity and it reports ok. Any ideas on how to rectify?
Looks to me as Audirvāna used to look in another place, and doesn’t see that anymore. Half of the songs show as not available, as if Audirvāna performed a scan but couldn’t get to that drive. But why that is I can’t say.
Hi @DonR,
As requested…
Audirvana Origin 2.5.21 (20522)
macOS 12.7.6 x86_64 with 8GB physical RAM
Connected account of : Don Ricciardiello
Effects plugins ACTIVE in realtime mode with legacy macOS API
	AU plugin #0: Effect - Dirac Research DiracLiveProcessor ()
	AU plugin #1: None
	AU plugin #2: None
	AU plugin #3: None
r8brain custom frequencies
44100Hz → 176400Hz
48000Hz → 192000Hz
88200Hz → 176400Hz
96000Hz → 192000Hz
352800Hz → 176400Hz
384000Hz → 192000Hz
Bandwidth = 90.1282%
Stop band attenuation 199.992dB
Phase minimum phase
Replay Gain: by album
SW volume control: ON
AUTO: /Users/donricciardiello/Music/Rips
Sort and display order: en
Library database path: /Users/donricciardiello/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 62653
Font size: regular
Library
My Music
Startup view: Library: Artists
Use Apple Remote: yes
Number of paired remotes: 5
Screen saver disabled: yes
Max. memory for audio buffers: 5628MB
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
DENAFRIPS USB v3.12 | H12.6F1.9
Model UID:DENAFRIPS USB v3.12 | H12.6F1.9:152A:86EF
UID:AppleUSBAudioEngine:DENAFRIPS:DENAFRIPS USB v3.12 | H12.6F1.9:14600000:1
Selected device:DENAFRIPS USB v3.12 | H12.6F1.9
Manufacturer: DENAFRIPS
Model name: DENAFRIPS USB v3.12 | H12.6F1.9
Model UID: DENAFRIPS USB v3.12 | H12.6F1.9:152A:86EF
UID: AppleUSBAudioEngine:DENAFRIPS:DENAFRIPS USB v3.12 | H12.6F1.9:14600000:1
USB Vendor ID: 0x152a
USB Product ID: 0x86ef
ID 0x39
12 available sample rates up to 1536000Hz
1411200
1536000
Max volume alert: Disabled
DSD via PCM 1.0
Stream ID 0x3a 2 channels starting at 1
24 virtual formats:
2 ch Mixable linear PCM Interleaved 32 little endian Signed Float 1536kHz
2 ch Mixable linear PCM Interleaved 32 little endian Signed Float 1411.2kHz
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 1536kHz
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 1411.2kHz
24 physical formats
2 ch Mixable linear PCM Interleaved 32 little endian Signed Integer 1536kHz
2 ch Mixable linear PCM Interleaved 32 little endian Signed Integer 1411.2kHz
Local devices found : 3
Device #0: ID 0x32 Built-in Output
Model UID: AppleHDA:108
Device #1: ID 0x39 DENAFRIPS USB v3.12 | H12.6F1.9
Device #2: ID 0x2c Dirac Virtual Audio Device
Manufacturer: Dirac Research AB
Model UID: com.dirac.vad_ModelUID
UID: com.dirac.vad_UID
Model name: Dirac Research AB Dirac Virtual Audio Device
Wi-Fi
UPnP devices found : 1
Device #0: ID 0x0 : VIERA ST60 Series
UID: uuid:4D454930-0100-1000-8001-8CC121FE3BED
Manufacturer: Panasonic
Model name: Panasonic VIErA
Chromecast devices found : 6
Device #0: All Speakers
Model name: Google Cast Group
Device #1: Garage speaker
Model name: Google Home Mini
Device #2: TV Room Speaker
Model name: Google Nest Mini
Device #3: Bedroom speaker
Device #4: Kitchen Display
Model name: Google Nest Hub
Device #5: Sound bar
Model name: LG SN Series ThinQ Soundbar
Do you have some playlists or favorites?
No, I just play albums.
Can you remove your AudirvanaDatabase.sqlite file?
You can go to it using Finder:
  1. On your keyboard, press the option (or alt) key and keep it pressed. This reveals the Library command in this Go menu. (if you still can’t see Library, please follow this procedure: How to Reveal the Library Folder in macOS - MacRumors)
  2. In the Finder window that opens, navigate into Application Support, then Audirvana
  3. You’ll find there the file AudirvanaDatabase.sqlite
I will try tomorrow. It’s after midnight in Australia. Good night.
Thank you @Antoine That fixed it :+1:
