So I downloaded the newest version of Audiovana Studio using the check for updates feature… Everything goes as expected… The new version seems to run and sound the same as the last version… All good… Except
LOL… No, I am not using the new EQ… I am using two plugins… The HangLoose Convolver and the Tone Projects Michelangelo EQ…
So, which is it? "No Signal Processing or 2 Signal Processors in RealTime?
Oops… Sorry if this got posted in the wrong forum…
While streaming from Qobuz or playing directly from a local file, same bogus message…
It should most likely read something to the affect of “No Audiovana EQ processing, 2 Signal Processors in RealTime”.
Not any worse than “No Signal Processing2 Signal Processors in RealTime2 Sign…”
Someone (Devo) needs to get their string concatenation correct… As well as answer the original question…
Instead of making fun of me… Tell Devo to fix the freak’in problem…
P.S. For an AI bot you sure are retarded!!!
You are a touchy one… I wasn’t making fun… I thought you were being clever and it made me laugh…
Hi @Ddude003 , can you please click on the steering wheel and send a screenshot of your settings? Are you using macOS or Windows?
I get same,
no processing…
while using plugin…
Is this what you are asking for?
MacOS Monterey 12.7.6 on a MacBook Pro i5 with 8GB…
thanks, I have been able to reproduce the issue, will check it with Damien.
Hi @Ddude003,
Please update to the latest version of Audirvāna Studio and let me know if you still have the issue.
Hi @Antoine, The update feature claims I have the latest release of Audirvana Studio and the debug window claims:
“Audirvana Studio 2.11.0 (21100)
macOS 12.7.6 x86_64 with 8GB physical RAM”
Same nonsensical problem as in my first post…
Will test a little later this evening…
Works and displays as expected…
“2 Signal Processors in RealTime”
Thank you!!!
