Hello!
I have a DAC Antelope Audio Amari, USB connection with MacMini 2019 latest SW status, there is a hard crash in connection with Audirvana.
Otherwise audio playback through AMARI from web or other sources works fine.
Hello!
Hi @MBOG,
Do you mean that Audirvāna Origin is crashing when you select your device? If it’s the case, can you send us the crash log generated? You can find it under the console app of MacOS in the Utilities folder of Applications.
