I am a beginner here. Does Audirvana come with any advanced audio settings (e.g. sounds equalizer, bass audio engine, etc.)?
The short answer is no⦠And the long answer is to find and use one to four plugins⦠There are literally thousands of high quality plugins available, some for free and some for $$$⦠Depending on your kit and what exactly you are trying to accomplish I am sure there would be plenty of suggestions from the Audirvana communityā¦
In case you are not getting the newsletterā¦
NEW INTEGRATED EQ (BETA)
From the photo/video loop it looks pretty plain jane as they come⦠I chose not to join the beta as I already have/use several top quality mastering EQ emulationsā¦
