.ape files not displaying properly
I have some albums that are one .ape files (don’t ask me why) with a .cue file to order the songs properly. It works fine on VLC but on Audirvana it shows as one big file name with the album name. The tracks are not separated and that is a bit annoying, especially cause it does not even display songs names.
Is there a way to correct it ? Thanks
Hi @AaronLaid,
can you send the fiel at support@audirvana.com? If the file is more than 20MB, please send an email and I will give you a link to upload the file.
