I have updated to version 3.5.26 on mac mini i5 with Catalina 10.15.1.
When i try to rename a new playlist and hit CAPS LOCK application just quit and an OSX problem report windows appear.
In fact, every time when the A is open and hit CAPS LOCK the application quits unexpected with error report.
Thank you for your reply, i can’t see everything in the crash report, can you copy-paste what’s inside of it?
Process: Audirvana [2396]
Path: /Applications/Audirvana.app/Contents/MacOS/Audirvana
Identifier: com.audirvana.Audirvana
Version: 3.5.26 (3556)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: Audirvana [2396]
User ID: 501
Date/Time: 2019-11-22 14:55:20.992 +0200
OS Version: Mac OS X 10.15.1 (19B88)
Report Version: 12
Anonymous UUID: 10E03AEB-ED16-EA65-F7F6-8C4963A47776
Time Awake Since Boot: 32000 seconds
System Integrity Protection: enabled
Crashed Thread: 22
Exception Type: EXC_BAD_INSTRUCTION (SIGILL)
Exception Codes: 0x0000000000000001, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Termination Signal: Illegal instruction: 4
Termination Reason: Namespace SIGNAL, Code 0x4
Terminating Process: exc handler [2396]
Application Specific Information:
BUG IN CLIENT OF LIBDISPATCH: Assertion failed: Block was expected to execute on queue [com.apple.main-thread]
Thread 0:: Dispatch queue: com.apple.main-thread
0 com.apple.AppleJPEG 0x00007fff4a263374 aj_huffman_decode_val + 4
1 com.apple.AppleJPEG 0x00007fff4a26ae4f aj_block_decode + 75
Thread 1:
0 libsystem_pthread.dylib 0x00007fff6e5ce56c start_wqthread + 0
Thread 2:
Thread 3:
Thread 4:: Dispatch queue: com.apple.root.default-qos
0 libsystem_kernel.dylib 0x00007fff6e50d916 __psynch_cvwait + 10
1 libsystem_pthread.dylib 0x00007fff6e5d2040 _pthread_cond_wait + 701
2 libc++.1.dylib 0x00007fff6b4fb81a std::__1::condition_variable::wait(std::__1::unique_lockstd::__1::mutex&) + 18
3 com.audirvana.Audirvana 0x00000001001682cb 0x100000000 + 1475275
4 com.audirvana.Audirvana 0x00000001000cc888 0x100000000 + 837768
5 com.audirvana.Audirvana 0x00000001001681be 0x100000000 + 1475006
6 libdispatch.dylib 0x00007fff6e37150e _dispatch_client_callout + 8
7 libdispatch.dylib 0x00007fff6e373358 _dispatch_queue_override_invoke + 763
8 libdispatch.dylib 0x00007fff6e37f7e2 _dispatch_root_queue_drain + 326
9 libdispatch.dylib 0x00007fff6e37ff22 _dispatch_worker_thread2 + 92
10 libsystem_pthread.dylib 0x00007fff6e5ce6d5 _pthread_wqthread + 220
11 libsystem_pthread.dylib 0x00007fff6e5ce57b start_wqthread + 15
End the last part:
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 18373
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=701.9M resident=0K(0%) swapped_out_or_unallocated=701.9M(100%)
Writable regions: Total=762.5M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=762.5M(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate framework 256K 2
Activity Tracing 256K 1
CG backing stores 440K 2
CG image 32K 1
CoreAnimation 35.0M 490
CoreGraphics 8K 1
CoreImage 8K 2
CoreUI image data 468K 7
Foundation 42.9M 83
Image IO 2940K 8
Kernel Alloc Once 8K 1
MALLOC 279.3M 109
MALLOC guard page 32K 7
MALLOC_NANO (reserved) 384.0M 1 reserved VM address space (unallocated)
Memory Tag 242 12K 1
STACK GUARD 56.1M 24
Stack 19.7M 24
VM_ALLOCATE 236K 15
__DATA 46.1M 428
__DATA_CONST 49K 5
__FONT_DATA 4K 1
__LINKEDIT 354.1M 12
__OBJC_RO 32.0M 1
__OBJC_RW 1780K 2
__TEXT 347.7M 419
__UNICODE 564K 1
mapped file 57.1M 19
shared memory 632K 13
TOTAL 1.6G 1680
TOTAL, minus reserved VM space 1.2G 1680
Model: Macmini6,1, BootROM 281.0.0.0.0, 2 processors, Dual-Core Intel Core i5, 2,5 GHz, 16 GB, SMC 2.7f1
Graphics: kHW_IntelHD4000Item, Intel HD Graphics 4000, spdisplays_builtin
Memory Module: BANK 0/DIMM0, 8 GB, DDR3, 1600 MHz, 0x0198, 0x393955353432382D3036332E4130304C4620
Memory Module: BANK 1/DIMM0, 8 GB, DDR3, 1600 MHz, 0x0198, 0x393955353432382D3035332E4130304C4620
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x10E), Broadcom BCM43xx 1.0 (7.21.190.33 AirPortDriverBrcm4360-1415)
Bluetooth: Version 7.0.1f1, 3 services, 27 devices, 1 incoming serial ports
Network Service: Ethernet, Ethernet, en0
Serial ATA Device: APPLE HDD HTS545050A7E362, 500,11 GB
Serial ATA Device: Crucial_CT256MX100SSD1, 256,06 GB
USB Device: USB 3.0 Bus
USB Device: Hub
USB Device: Hub
USB Device: Hub
USB Device: HD Pro Webcam C920
USB Device: Hub
USB Device: USB 2.0 Bus
USB Device: Hub
USB Device: Hub
USB Device: IR Receiver
USB Device: BRCM20702 Hub
USB Device: Bluetooth USB Host Controller
USB Device: Hub
Thunderbolt Bus: Mac mini, Apple Inc., 23.4
@bvladimir, we can’t see the info we need to understand the crash report, can you send me in private message the entire crash report please?
Report has over 96000 characters
