AS crashed when trying to open "Various Artists"
In my artists list I have one called “various artists”. It contain compilation albums such as movie sound tracks. If I try to open it in AS, it crashes AS. Does anyone have any idea why this could be happening? Debug info below.
Audirvana Studio 2.8.2.3 (20802)
macOS Version 14.5 (Build 23F79) with 16GB physical RAM
Connected account of : Daz Davies
AUTO: /Volumes/2TB SSD/Music
Library database path: /Users/dazdavies/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Fingerprinting track 6838/10272 : /Volumes/2TB SSD/Music/Bruce Springsteen/The Ghost of Tom Joad/06 The Line.aif
Listening on 127.0.0.1 on port 57542
TIDAL: Connected as PREMIUM
UI theme: light
Font size: regular
Language: English
My Music
Streaming
Radios
Podcasts
Startup view: Local Library: Artists
Use Apple Remote: yes
Number of paired remotes: 1
Screen saver disabled: no
Active method: UPnP
Preferred device: [UPnP] WiiM Pro Plus-8742 Model UID:Linkplay Technology Inc. WiiM Pro Plus-8742 UID:uuid:FF98FCDE-B87F-D56A-6AA6-F401FF98FCDE
Selected device:WiiM Pro Plus-8742
Manufacturer: Linkplay Technology Inc.
Model name: WiiM Pro Plus-8742
Model UID: Linkplay Technology Inc. WiiM Pro Plus-8742
UID: uuid:FF98FCDE-B87F-D56A-6AA6-F401FF98FCDE
UPnP device at http://192.168.1.34:49152/description.xml
ID 0x0
Volume control: Yes
Max volume alert: Disabled
UPnP set capabilities
Maximum PCM bitdepth set: 32
Not native DSD capable
Avoid RAW PCM streams: Yes
http-get::audio/wav:DLNA.ORG_PN=LPCM
http-get:
:audio/x-wav:DLNA.ORG_PN=LPCM
http-get:
:audio/mpeg:DLNA.ORG_PN=MP3X
http-get:
http-get:
:audio/mpeg:DLNA.ORG_PN=MP2_MPS
http-get::audio/mp3:
http-get::audio/wma:
http-get::audio/mpeg:
http-get:
:audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS_320
http-get::audio/m4a:DLNA.ORG_PN=AAC_ISO
http-get:
:audio/aac:DLNA.ORG_PN=AAC_ISO
http-get::audio/ac3:DLNA.ORG_PN=AC3
http-get:
:audio/ogg:*
http-get::audio/ape:
http-get::audio/x-ape:
http-get::audio/flac:
DLNA 1.5: Yes
Native Gapless playback: Yes
Missing events workaround: No
Can play native DSD: No
Volume Control: scalar
30 virtual formats:
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 44.1kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 88.2kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 176.4kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 352.8kHz finite length
2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 705.6kHz finite length
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 705.6kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 705.6kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 48kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 96kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 192kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 384kHz finite length
2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 768kHz finite length
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 768kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 768kHz finite length
0 physical formats
NrTracks: 1
MediaDuration: 00:03:48
CurrentURI: http://192.168.1.10:49152/audirvana/audio_f_13.wav
CurrentURIMetadata: <?xml version="1.0"?>
dc:titleSing</dc:title>
dc:creatorTravis</dc:creator>
upnp:artistTravis</upnp:artist>
upnp:genre</upnp:genre>
upnp:albumArtURIhttp://resources.tidal.com/images/53797be7/dec4/4a7c/a24a/00cb9fcce5b2/640x640.jpg</upnp:albumArtURI>
upnp:albumThe Invisible Band</upnp:album>
song:rate_hz44100</song:rate_hz>
song:format_s16</song:format_s>
song:bitrate1411</song:bitrate>
nextURI: http://192.168.1.10:49152/audirvana/audio_f_14.wav
Side Travis Travis http://resources.tidal.com/images/53797be7/dec4/4a7c/a24a/00cb9fcce5b2/640x640.jpg The Invisible Band 3 object.item.audioItem.musicTrack http://192.168.1.10:49152/audirvana/audio_f_14.wav
PlayMedium: THIRD-DLNA
Current transport actions:
Play,Stop
<?xml version="1.0"?> 1 0 DMR-1.50 urn:schemas-upnp-org:device:MediaRenderer:1 WiiM Pro Plus-8742 Linkplay Technology Inc. https://wiimhome.com WiiM Pro Plus Receiver WiiM Pro Plus Receiver https://wiimhome.com uuid:FF98FCDE-B87F-D56A-6AA6-F401FF98FCDE V01-Jul 8 2024 00001 WiiM Pro Plus-8742 FF98FCDEB87FD56A6AA6F401 QPlay:2 image/png 48 48 24 /upnp/grender-48x48.png image/png 120 120 24 /upnp/grender-120x120.png image/jpeg 48 48 24 /upnp/grender-48x48.jpg image/jpeg 120 120 24 /upnp/grender-120x120.jpg urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /upnp/rendertransportSCPD.xml /upnp/control/rendertransport1 /upnp/event/rendertransport1 urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /upnp/renderconnmgrSCPD.xml /upnp/control/renderconnmgr1 /upnp/event/renderconnmgr1 urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /upnp/rendercontrolSCPD.xml /upnp/control/rendercontrol1 /upnp/event/rendercontrol1 urn:schemas-wiimu-com:service:PlayQueue:1 urn:wiimu-com:serviceId:PlayQueue /upnp/PlayQueueSCPD.xml /upnp/control/PlayQueue1 /upnp/event/PlayQueue1 urn:schemas-tencent-com:service:QPlay:1 urn:tencent-com:serviceId:QPlay /upnp/QPlaySCPD.xml /upnp/control/QPlay1 /upnp/event/QPlay1
UPnP devices found : 3
Device #0: ID 0x0 : Marantz PM7000N
UID: uuid:a1838f15-12ce-1edc-0080-000678c1b5ea
Location: http://192.168.1.3:60006/upnp/desc/aios_device/aios_device.xml
Manufacturer: Marantz
Model name: Marantz PM7000N
Device #1: ID 0x0 : WiiM Pro Plus-8742
Device #2: ID 0x0 : Bose Soundbar 500
UID: uuid:d7f33b81-4996-5ac1-e364-4acccd6e3183
Location: http://192.168.1.4:8091/d7f33b81-4996-5ac1-e364-4acccd6e3183.xml
Manufacturer: Bose
Model name: Bose Soundbar 500
Max. memory for audio buffers: 4084MB
Local Audio Engine: CoreAudio
Local devices found : 4
Device #0: ID 0x61 DELL U2720Q
Manufacturer: DEL
Model UID: 10ACB041-0000-0000-321E-0103803C2278
Model name: DELL U2720Q
Device #1: ID 0x5a External Headphones
Model UID: Codec Output
UID: BuiltInHeadphoneOutputDevice
Model name: Apple Inc. External Headphones
Device #2: ID 0x54 Mac mini Speakers
Model UID: Speaker
UID: BuiltInSpeakerDevice
Device #3: ID 0x4a Microsoft Teams Audio
Manufacturer: Microsoft Corp.
Chromecast devices found : 1
Device #0: WiiM Pro Plus-8742
Model name: WiiM Pro Receiver
Hi @Dazza,
Can you please send us the crash file generated at [email protected]?
Done.
