Hello. Since upgrading to Big Sur, I have been getting very infrequent dropouts (maybe once every 2 hours). I am using a Schiit Eitr to Modi Multibit DAC.
Thanks.
Thanks.
Thanks for your response.
macOS 10.16.0 with 8192MB RAM
Registered to Ricardo Brunet
AUTO: /Volumes/MMV/Music (FLAC)
Library database path: /Users/rickbrunet/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Schiit Eitr
Model UID:Schiit Eitr:0D8C:0004
UID:AppleUSBAudioEngine:Schiit Audio:Schiit Eitr:14600000:1
Hog Mode is on
ID 0x48 Schiit Eitr Manufacturer:Schiit Audio
Model UID:Schiit Eitr:0D8C:0004 UID:AppleUSBAudioEngine:Schiit Audio:Schiit Eitr:14600000:1
Stream ID 0x49 2 channels starting at 1
18 virtual formats:
24 physical formats
Local devices found : 3
Device #0: ID 0x51 G257HU Manufacturer: Apple Inc. Model UID: AppleGFXHDA:0 UID: AppleGFXHDAEngineOutputDP:f803:0:{7204-0416-8190000D}
Device #1: ID 0x48 Schiit Eitr Manufacturer: Schiit Audio Model UID: Schiit Eitr:0D8C:0004 UID: AppleUSBAudioEngine:Schiit Audio:Schiit Eitr:14600000:1
Device #2: ID 0x4b Mac mini Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice
Do you have the same issue when you are using your mac mini speakers?
No, but I hardly ever use them.
The thing is, I can go 12 hours without any dropouts, and then get 2 dropouts within an hour. I guess it points to a problem with Big Sur, since that is the only change that has been made to the system.
Does it happens with any kind of frequency you try to play?
I mostly play 16/44. But it happens with 24/96 also.
Something I should perhaps mention, this is like deja vu, because I went through this problem on macOS a few years ago. Back then, it was determined that the daemon Timed was causing the dropouts and it was ultimately fixed (after a very long, long time) by Apple.
