I have to login via web to account again and restart Audirvana Origin to get it work. It repeats on daily basis. It’s Audirvana Origin 2.0.4. Is there a solution to this bug?
Hello @jaje,
Can you disconnect and then reconnect your account? To do this you need to go to Audirvāna settings, My Account section.
It works, thanks.
Hi,
I also had a problem with the Audio HD Analysis not working after updating to version 2.4.0.
Disconnecting and reconnecting to my account again, solved the issue.
