Audio mutes/cracks when syncing folders
Hi, still having audio pops, cracks and mutes when syncing music folders
Coreaudiod :
HALS_IOA1Engine::EndWriting: got an error from the kernel trap, Error: 0xE00002EE
Then console is full of :
HALS_OverloadMessage.cpp:222 HALS_OverloadMessage: Overload due to HAL client proc exceeding io cycle budget
Bonjour @Claude,
Pouvez-vous ouvrir l’application Moniteur d’activité de MacOS et vérifier si votre processeur n’est pas au maximum de ces capacités lorsque vous avec ce message dans l’application Console?
Audirvana can actually reach 460% CPU when playing and syncing at the same time (Mac mini i7 16Go).
Attempting playback at the same time as the initial syncing process is quite likely to have poor results, best to let it finish if you can. Good luck with it
Which generation of Mac Mini?
It’s a 2018, here’s the screenshot :
