Hello,
i have restarted several times Audirvana, but i cannot read any file in my library.
i did not change my setup since last time, but don’t know why it is not working
please find the debug info
Audirvana 3.5.40
SW volume control: ON
AUTO: W:\Audirvana
Library database path: C:\Users\jdagr\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 11346MB
Local Audio Engine:ASIO 2 driver version 3
Realtek Digital Output (Realtek® Audio)
Model UID:Realtek Digital Output (Realtek® Audio)
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{f57b6ffd-601b-43df-9aec-4073836d79e0}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Realtek ASIO Manufacturer:
Model UID:Realtek ASIO UID:Realtek ASIO
4 available sample rates up to 192000Hz
Multichannel: 8 channels
Channel bitmap: Ox63f, layout:
Channel 2 mapped to 2
Channel 3 mapped to 3
Channel 4 mapped to 4
Channel 5 mapped to 5
Channel 6 mapped to 6
Channel 7 mapped to 7
Number of channels: 8
Simple stereo device: No
8 ch Integer PCM 24bit little endian 44.1kHz
8 ch Integer PCM 24bit little endian 48kHz
8 ch Integer PCM 24bit little endian 96kHz
8 ch Integer PCM 24bit little endian 192kHz
Device #0: Realtek ASIO Manufacturer: Model UID: Realtek ASIO UID: Realtek ASIO
thanks for your help
best regards
