Audio track sequence
Hello,
perhaps some of you have had the same problem, namely that of creating a folder on the hard disk that contains a selection of tracks numbered in sequence, but once the folder is opened in Audirvana Origin the order in which the tracks are read is completely disrupted.
I would like to ask for help if anyone has found a solution so that I can listen to the tracks in the order set.
Creating the sequence with Audirvana’s play list is tiring when searching for individual tracks.
Asus DeskTop i3 - RAM 12 GB Windows 10
Thank you very much
Hello @Salvatore_Di_Tommaso
This has happened to me.
I simply edited the track sequences in the Individual tracks in “Edit metadata”.
You will need to know the order of the tracks from the booklet…
Regards
Phil .
