Audio Unit / Sonarworks SoundID not usable
Once SoundID (5.2.3.2 or the newest 5.3.) is configured as Audio Unit, Audirvana Origin cannot be used anymore. The macOS spinball appears and the CPU load increases. This is not the case with Audirvana 3.5.50.
Audirvana Origin 1.0.4 (10004)
macOS Version 12.4 (Build 21F79) with 16GB physical RAM
Connected account of : sbmn
Effects plugins ACTIVE in offline mode with legacy macOS API
	AU plugin #0: Effect - Sonarworks SoundID Reference Plugin ()
	AU plugin #1: None
	AU plugin #2: None
	AU plugin #3: None
r8brain with Power Of Two upsampling
Phase minimum phase
Sync list: 3 folders
AUTO: /Users/swen/Music/HighRes Flac
AUTO: /Users/swen/Music/iTunes/iTunes Media
AUTO: /Users/swen/Music/SA-CD RIP
Library database path: /Users/swen/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 50578
Max. memory for audio buffers: 4016MB
HDMI
Model UID:AppleHDA:128
UID:AppleHDAEngineOutputDP:0,1,0,1,0:0:{EE11-006B-01010101}
Active Sample Rate: 96kHz
ID 0x2c Ausgang (integriert)
Model Name: Apple Inc. Ausgang (integriert)
Model UID: AppleHDA:128
Stream ID 0x2d 2 channels starting at 1
4 virtual formats:
12 physical formats
Device #0: ID 0x2c Ausgang (integriert) Manufacturer: Apple Inc. Model UID: AppleHDA:128 UID: AppleHDAEngineOutput:1B,0,1,1:0 Model Name: Apple Inc. Ausgang (integriert)
Device #1: ID 0x3d Soundflower (2ch) Manufacturer: ma++ ingalls for Cycling '74 Model UID: com_cycling74_driver_SoundflowerDevice:Soundflower UID: SoundflowerEngine:0 Model Name: ma++ ingalls for Cycling '74 Soundflower (2ch)
Something happened in the latest SoundID Ref (Sonarworks) AU plugin (5.3.0) that broke it within Studio (v1.13.0). It no longer can render though it and the audio bus refuses to start.
I’ve tried this version of the AU plugin with other hosts like Audacity on the Mac and there it works fine.
Hello @sbmn and @phelme,
Can you please enable this option and try again?
When enabling this option Audirvana plays my files. Going back Audirvana crashes.
What do you mean by that?
Sorry. I mean switching back to the standard API.
Regards
Sonarworks seems to be working for me now. They released an update.
Now my problem is Audirvana Studio can’t remember I’ve turned off individual Audio Units and keeps displaying them no matter what I do. This has happened in the past. :frowning:
You mean by that deselecting it?
Correct. As far I know the only way to do it is by setting “No Effect”
You can do this that way or completely disable audio unit with the button on the same page of the settings. Either way you still have the audio unit displayed when you play?
when I disable the entire effects processor, no AU plugin is displayed, as expected.
but this is a continuing bug that there appears to be no way to reliably remove individual effects from the 4 slots without tossing the entire SQLite database and recreating everything.
removing effects plugins works OK on Windows, this is a Mac problem as far as I can tell.
Which version of MacOS do you have?
v12.4
Hello @phelme,
I’m really sorry for the late reply, can you please try to reproduce your issue with the latest version of Audirvāna Studio and the latest version of SoundID?
installed the latest. there is still one plugin (from Voxengo) in the 2nd slot that just won’t go away. I can install another type in the same place, but once that is removed the Voxengo just comes back. Same with setting it to “No Effect”
Audirvana Studio 1.13.3 (11303)
Connected account of : pete helme
	Per track: OFF
	AU plugin #0: None
	AU plugin #1: Effect - Voxengo PrimeEQ ()
	AU plugin #2: None
	AU plugin #3: None
Are you sure there is not one copy in the main Library or one in the User Library?
If you can’t see your User Library by default:
I have the same problem: when I select SoundID and then configure, Audirvana origin is crashing and sending a report to Apple. All the 0ptions in the audio units screen are set to ‘on’.
Is this a Audirvana problem or SoundID problem, and how can we solve it?
gr. Jos.
Hello @Jos,
Can you please send us the content of the crash report at [email protected]? Are you using the latest version of their plugin?
