What other audio application, driver, … (e.g Audio Hijack or other) is installed?
Yes Audio Hijack was installed.
I uninstalled this app, but it doesn´t solve the problem
Have you rebooted after uninstalling Audio Hijack (it’s its InstantOn module that causes an issue)?
If you still get the error message, can you send me a screenshot of it by email?
Yes I rebootet after the uninstalling.
you see the problem in the red frames.
This is the screen after clicking a song.
“Stopping audio device…”
“Quit Audirvana Plus” ist grey.
The green “INT” symbol is also not to see.
At last I have to go to “Force quit” to end A+
May be it is helpful
Is there a chance, or is my DAC device (Manunta HiFACE) since A+3 incompatible?
This device is displayed as active audio device in the preferences (audio system): hiFaceDAC UAC2 Output
An answer would be nice !
After clean Installation from El Capitan same mistake:
"Stopping audio device…"
Thanks for Audirvana Plus 3.03
a bad choice
I have the same problem with the new Fiio X5 3rd generation and audirvana 3.04 . Everything was working fine with the Fiio X5 2nd generation and audirvana 2.6. I tried to clean and reinstall A3.04 but the problem is the same. It’s not possible to use it as USB DAC. I’m a bit frustrated as I sold my old Fiio X5
Just to check: do you have the option in the Audio System page: “Auto-detect MQA devices” NOT checked?
There are some DAC USB interfaces that can be triggered to crash when polled for MQA compatibility. So this option should NOT be checked unless you have a MQA DAC.
No. This option is not checked.
Bonjour
J’avais le même problème. Curieusement je pouvais ecouter de la musique sur Qobuz via audirvana, preuve que la liaison avec le DAC n’était pas en cause (Chord Mojo)
en revanche impossible d’écouter quoi que ce soit en FLAC, Apple losseless, DSD, … (mode integré à itune actif ou pas)
Du coup, je suis revenu (avec du mal, merci Time Machine … ) à la version 2.6.6 qui fonctionne sans problème en attendant que le problème soit résolu dans une future mise à jour.
Je n’ai pas retesté en 3.04. J’avoue que je suis devenu un peu frileux …
Bertrand
it looks like the end of Audirvana . 2.6.6 was the last Version that is working without problems
- Can you send me (by PM or email) the Debug Info (Audirvana Plus menu command) so I can check you don’t have any weird settings
- Can you try to drop a file directly from the Finder on the Play Queue, and play from there? This will bypass any library management. And issues like a lost link to your files (in case there are on an external volume that has changed?).
Still trying to understand what is different on your system and causes this issue…
