mNON RIESCO PIU’ A SENTIRE LA MIA MUSICA AIUTOOOOOOOO TUTTE LE TRACCE SONO CON I CARATTERI GRIGI
acOS 10.12.1 with 8192MB RAM
Registered to Berardo Di Bartolomeo
Per track: OFF
iZotope SRC not in use iZotope SRC filter parameters
Steepness = 150
Filter max length = 500000
Cut-Off (x Nyquist) = 100%
Anti-aliasing = 200
Phase = 100%
SW volume control: ON
Sync list: 2 folders
AUTO: /Volumes/MUSICA/LIBRERIA MUSICALE/I TUNES
AUTO: /Volumes/MUSICA/PLAYLIST ADINIRVANA
Library database path: /Users/berardodibartolomeo/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Exclusive access: Disabled
Integer mode: Disabled
Audiolab 8200 Series
Model UID:Audiolab 8200 Series:0451:8200
UID:AppleUSBAudioEngine:Lakewest Audio:Audiolab 8200 Series:14200000:2
Sample rate limitation: 48kHz
ID 0x38 Audiolab 8200 Series Manufacturer:Lakewest Audio
Model UID:Audiolab 8200 Series:0451:8200 UID:AppleUSBAudioEngine:Lakewest Audio:Audiolab 8200 Series:14200000:2
Stream ID 0x39 2 channels starting at 1
8 virtual formats:
8 physical formats
Device #0: ID 0x2e Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:123 UID: AppleHDAEngineOutput:1B,0,1,1:0
Device #1: ID 0x38 Audiolab 8200 Series Manufacturer: Lakewest Audio Model UID: Audiolab 8200 Series:0451:8200 UID: AppleUSBAudioEngine:Lakewest Audio:Audiolab 8200 Series:14200000:2
