Installation of new version was successful after unistall of old 3.46, however now the program exits after trying to find the library. I’ve followed the instructions and copied the old library in the folder where I found the new one created by the installation. A message appears saying Audirvana has exited unexpectedly. A dump filehas been created. Any suggestions ? Should I re-install 3.5.50 ? Thanks
Problem solved. I reinstalled 3.5.50 and copied my library into a folder with a less abstruse pathway than the one created during the installation. Audirvana works now perfectly.
