Audirvana always sync at startup
Hi guys,
I noticed recently that Audirvana always make a sync at startup, even if i’ve not added files in my library, that was not the case before.
As i have a pretty large library (215’000 tracks), this is a bit annoying because it takes some time to let me choose a playlist or whatsoever i want to do in Audirvana.
Is it possible to have an explanation Damien ? or at least fix this “issue” please.
Otherwise i’m very happy and pleased with this new version !
Best regards.
Bonjour @Lolodesiles
Please see also an opposite behaviour in the discussion
Greetings, Martin
Hello Martin,
Je ne sais pas sur quelle version tu es, mais moi en v 3.5.26 sous OSX 10.14.1, je n’ai pas le choix pour la synchro auto ou manuelle sur un lecteur local, je suis d’office en auto, ce qui ne me pose pas de problème vu que j’ajoute souvent des fichiers à ma biblio.
Merci de ta réponse.
J’utilise Audirvana 3.5.2 sur Windows 10.
Cf.
  • En cas de “AUTO” et “Always sync on startup” Audirvana functions like expected: it always syncs on startup.
  • En cas de “AUTO” et “Always sync on startup: NO” Audirvana functions like expected: it does not sync on startup. -> And if I understand you right, @Lolodesiles, in your installation the behaviour is different.
  • En cas de “Manual” et “Always sync on startup” Audirvana DOES NOT FUNCTION like expected: it does not sync on startup but it should! @Damien3: Qu’est-ce que vous y pensez?
  • En cas de “Manual” et “Always sync on startup: NO” Audirvana functions like expected: it does not sync on startup.
Hello all - i would be tempted to think this is a difference between macosx and win10. I use a Mac and even though it does refresh everytime i open A, i can use it and listen. It blinks a little bit and sometimes crashes, so i avoid oding this and be patient a few seconds.
On the flip side, my father uses it on a PC (and has a lot more albums than me). Both of us store music on a NAS. He can absolutely NOT not use A until the whole sync process is finished, which takes very long minutes, each time!
I have been trying to get him on A since years, he has finally purchased licenses, and now it is a difficult sell, as the user friendliness is less than perfect … :///
Hello @danberilloux and @Lolodesiles,
You can try by deactivate the auto startup sync on Windows 10 since the mechanism to sync files is a bit different on MacOS and Windows 10. If you do that you have to be aware that if you make some change in your library you will have to manually synchronize your library to be up to date.
Thanks @Damien3 it looks like the best option for PC users indeed. Have you had a chance to take a look at the famous “duplicate” issue, that a lot of us have discussed in this forum (another topic with many responses + my email to you a few weeks ago)?
The duplicate issue are related to iTunes, which we can’t control that it can make duplicate of your files in your computer. We know its a annoying issue but it is definitely not an Audirvana issue.
thanks @Damien3 … but no, i am not using iTunes since years, neither is @RunHomeSlow and a few others here … The duplicate files appear typically when you add or move tracks/folders in a watched folder, or between watched folders, while Audirvana is running. It seems to “never forget” the old location, while indexing the new location too. This can be worked around by only doing movements of files/folders while Audirvana is closed, and letting it sync cleanly when you open it … but really not ideal.
I can explain further (in french) if you need more information to debug. This is clearly a problem.
Hello everybody,
I use audirvana on mac with great satisfaction.
what I just can’t solve is to avoid synchronization every time I start the program … I can’t change the option from always on start up to manual. furthermore, the word synchronization in progress never disappears.
do you have any idea how to solve it?
thank you very much
Kris
Hello @Teddy_k, you mean you can’t disable this button?
hello!
yes and the word “auto” remains in the string(moreover i can’t modify from auto to manual)
tks
Kris
What is the path of the folder you had synchronized? The “Auto” next to your synced library means that it will detect automatically any change in this folder (like metadata edit or adding new files)
the folder containing the music is inside an external usb3 disk.
what is strange is that audirvana performs the synchronization at every opening of the program regardless of the option selected in rescan network folders at each start (enabling or disabling nothing changes)
Hello @Teddy_k, Do you only have your music stored in your portable drive? If you have other thing that could be use by your pc like auto backup this would cause Audirvana to detect activity in it and scan it again.
Have you also stored your Audirvana database in it?
Hello @Damien3,
the only hard disk that contains audio material is an external usb3 disk. the audirvana database is in the mac hard disk of the mac.
there are no active backup software and the mac time machine is deactivated …
So you just have your music stored in it and it is located in the path you mention in Audirvana?
Yes exactly Damien, all my music is stored in the external usb3 hd, the path is \Volumes\Western_Blu\la MuSIca
@Damien3 you just triggered a thought that could explain many of my issues.
Since i store my music files in a dedicated folder of a NAS, and this NAS has 2 hard drives in mirroring mode (RAID1), could this be seen by A as a “moving target”? meaning, everytime one disc mirrors its brother disc, A sees that as a change?
I suffer the now classic “duplicates” problem, that many other users face too.
I also have a problem with the Recently Added smart playlist: it shows tracks that i have played recently, but added years ago … it seems to confuse “added” and played" … for some reason …
