I set up the trial Windows Version, am I right or did the Pioneer works only as a USB Dac with Audirvana? If I like to Play MQA files from Tidal I get the message, no Audio files loaded.
Yes, at the moment it appears to be the case. Just connect via USB and select MQA decoder if it’s not automatically detected.
Sorry but it is not possible to play MQA files from Tidal with this setup
Not sure if this device supports MQA over USB. Check the manual.
There‘s also currently an issue with the Windows version of Audirvana and MQA. Check the forums for details. It should be fixed soon.
