Hello thanks for replying.
At the moment I’m not upsampling. Sometimes I like to try to see if improves the sound.
I think once I accidently changed the usb port. Didn’t make any difference.
Here’s the debug info.
macOS 10.14.6 with 16384MB RAM
Registered to me
Replay Gain: by album
AUTO: /Volumes/1.LOSSLESS/Lossless
Library database path: /Users/muziekspeler/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Pre Box S2 Digital
Model UID:Pre Box S2 Digital:2772:0230
UID:AppleUSBAudioEngine:Pro-Ject:Pre Box S2 Digital:14100000:1
Device: 2ch Non-mixable linear PCM Interleaved 32bits little endian Signed Integer, 8 bytes per frame 44.1kHz
Hog Mode is on
ID 0x36 Pre Box S2 Digital Manufacturer:Pro-Ject
Model UID:Pre Box S2 Digital:2772:0230 UID:AppleUSBAudioEngine:Pro-Ject:Pre Box S2 Digital:14100000:1
Stream ID 0x37 2 channels starting at 1
20 virtual formats:
20 physical formats
Device #0: ID 0x2e Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:82 UID: AppleHDAEngineOutput:1B,0,1,1:0
Device #1: ID 0x36 Pre Box S2 Digital Manufacturer: Pro-Ject Model UID: Pre Box S2 Digital:2772:0230 UID: AppleUSBAudioEngine:Pro-Ject:Pre Box S2 Digital:14100000:1
UPnP devices found : 1
Device #0: ID 0x0 Computerkamer UID: uuid:9ab0c000-f668-11de-9976-ac44f2418dcc
