Audirvana beta for windows will not load.
Hello Damien
When i try to load Audirvana beta for windows i get the following error message when “Visual C++ “14” Runtime Libraries (x64)” try’s to load.
“Cannot continue. The application is improperly formatted. Contact the application vender for assistance”
Hear is the error report.
PLATFORM VERSION INFO
Windows : 10.0.16299.0 (Win32NT)
Common Language Runtime : 4.0.30319.42000
System.Deployment.dll : 4.7.2556.0 built by: NET471REL1
clr.dll : 4.7.2633.0 built by: NET471REL1LAST_C
dfdll.dll : 4.7.2556.0 built by: NET471REL1
dfshim.dll : 10.0.16299.15 (WinBuild.160101.0800)
SOURCES
Deployment url : https://audirvana.com/delivery/apluswin/AudirvanaPlus.application
Deployment Provider url : https://audirvana.com/delivery/apluswin/AudirvanaPlus.application
IDENTITIES
Deployment Identity : AudirvanaPlus.application, Version=0.99.0.1013, Culture=neutral, PublicKeyToken=44075894dcec301c, processorArchitecture=amd64
APPLICATION SUMMARY
  • Installable application.
ERROR SUMMARY
Below is a summary of the errors, details of these errors are listed later in the log.
COMPONENT STORE TRANSACTION FAILURE SUMMARY
No transaction error was detected.
WARNINGS
There were no warnings during this operation.
OPERATION PROGRESS STATUS
ERROR DETAILS
Following errors were detected during this operation.
  • [20/06/2018 14:48:38] System.Deployment.Application.InvalidDeploymentException (ManifestParse)
  • Exception reading manifest from https://audirvana.com/delivery/apluswin/Application%20Files/AudirvanaPlus_0_99_0_1013/AudirvanaPlus.exe.manifest: the manifest may not be valid or the file could not be opened.
  • Source: System.Deployment
  • Stack trace:
    at System.Deployment.Application.ManifestReader.FromDocument(String localPath, ManifestType manifestType, Uri sourceUri)
    at System.Deployment.Application.DownloadManager.DownloadApplicationManifest(AssemblyManifest deploymentManifest, String targetDir, Uri deploymentUri, IDownloadNotification notification, DownloadOptions options, Uri& appSourceUri, String& appManifestPath)
    at System.Deployment.Application.ApplicationActivator.DownloadApplication(SubscriptionState subState, ActivationDescription actDesc, Int64 transactionId, TempDirectory& downloadTemp)
    at System.Deployment.Application.ApplicationActivator.InstallApplication(SubscriptionState& subState, ActivationDescription actDesc)
    at System.Deployment.Application.ApplicationActivator.PerformDeploymentActivation(Uri activationUri, Boolean isShortcut, String textualSubId, String deploymentProviderUrlFromExtension, BrowserSettings browserSettings, String& errorPageUrl, Uri& deploymentUri)
    at System.Deployment.Application.ApplicationActivator.PerformDeploymentActivationWithRetry(Uri activationUri, Boolean isShortcut, String textualSubId, String deploymentProviderUrlFromExtension, BrowserSettings browserSettings, String& errorPageUrl)
    — End of stack trace from previous location where exception was thrown —
    at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
    at System.Deployment.Application.ApplicationActivator.ActivateDeploymentWorker(Object state)
    — Inner Exception —
  • Parsing and DOM creation of the manifest resulted in error. Following parsing errors were noticed:
    -HRESULT: 0x8007001f
    Start line: 0
    Start column: 0
    Host file:
  • Stack trace:
    at System.Deployment.Application.Manifest.AssemblyManifest.LoadCMSFromStream(Stream stream)
    at System.Deployment.Application.Manifest.AssemblyManifest…ctor(FileStream fileStream)
    — Inner Exception —
    System.Runtime.InteropServices.COMException
  • A device attached to the system is not functioning. (Exception from HRESULT: 0x8007001F)
  • Stack trace:
    at System.Deployment.Internal.Isolation.IsolationInterop.CreateCMSFromXml(Byte[] buffer, UInt32 bufferSize, IManifestParseErrorCallback Callback, Guid& riid)
COMPONENT STORE TRANSACTION DETAILS
No transaction information is available.
I am using a HP Spector x360 laptop with windows 10 home edition , 8GB ram, i7 processor.
Edward
Can you try again? I’ve just released build 1014.
Thanks,
Damien
Hello Damien
just spent a few hours resetting windows 10 update as it could not complete it’s updates, reset windows and updated to current version.
Audirvana now installed, loading music files as I type.
Thank you for all your hard work.
Edward
