Hi,
Sorry, not sure if this is the right place to post about this issue.
I’ve been having the problem for a few weeks of Audirvana playing fine for 12 minutes or so then just stopping in the middle of a track. Attempting to get it to play again results in little blue circle going round and round for ever and I have to close the program and start again. Today I uninstalled Audirvana and reinstalled again. , but still the same problem.
ASIO USB into RME DAC. I’m pretty sure my wifi is solid and good, any ideas anyone, Damien?
Bug info here, but doesn’t seem to show any activity.
Audirvana 3.5.45
Polarity Inversion:Globally: OFFPer track: ON Effects plugins NOT ACTIVE
UPSAMPLING: SoX not in use SoX filter parametersBandwidth at 0dB = 99.5Filter max length = 30000Anti-aliasing = 100Phase = 66
AUDIO VOLUME: Max allowed volume: 100 Replay Gain: None SW volume control: OFF
LIBRARY SETTINGS: Sync list: 0 folders Library database path: C:\Users\james\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
ACTIVE STREAMING SERVICES TIDAL: Connected as HIFI
Max. memory for audio buffers: 774MB
Local Audio Engine:ASIO 2 driver version 1
Preferred device: Analog (1+2) (RME ADI-2 DAC) Model UID:Analog (1+2) (RME ADI-2 DAC) UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{1a897715-4a7f-4089-aceb-777d96aaa2a6}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Active Sample Rate: 176.4kHz
Bridge settings: Sample rate limitation: none Sample rate switching latency: none Limit bitdepth to 24bit: OFF Mute during sample rate change: OFF
Selected device: Local audio deviceASIO MADIface USB Manufacturer: Model UID:ASIO MADIface USB UID:ASIO MADIface USB
13 available sample rates up to 11289600Hz 44100 48000 88200 96000 176400 192000 352800 384000 705600 768000 2822400 5644800 11289600Volume Control Physical: No Virtual: NoMQA capability Auto-detect MQA devices: Yes Not a MQA device, user set to not MQADSD capability: Raw DSD (MSB)Device audio channels Preferred stereo channels L:0 R:1 Channel bitmap: Ox3, layout:Channel 0 mapped to 0Channel 1 mapped to 1
Audio channels in use Number of channels: 2 Use as stereo device only: No Simple stereo device: Yes
1 output streams: Number of active channels: 2, in 1 stream(s)Channel #0 :Stream 0 channel 0Channel #1 :Stream 0 channel 1 2 ch Integer PCM 32bit little endian 44.1kHz 2 ch Integer PCM 32bit little endian 48kHz 2 ch Integer PCM 32bit little endian 88.2kHz 2 ch Integer PCM 32bit little endian 96kHz 2 ch Integer PCM 32bit little endian 176.4kHz 2 ch Integer PCM 32bit little endian 192kHz 2 ch Integer PCM 32bit little endian 352.8kHz 2 ch Integer PCM 32bit little endian 384kHz 2 ch Integer PCM 32bit little endian 705.6kHz 2 ch Integer PCM 32bit little endian 768kHz 2 ch DSD 8bit big endian in 8bit chunk 2822.4kHz 2 ch DSD 8bit big endian in 8bit chunk 5644.8kHz 2 ch DSD 8bit big endian in 8bit chunk 11289.6kHz
Local devices found : 2Device #0: ASIO MADIface USB Manufacturer: Model UID: ASIO MADIface USB UID: ASIO MADIface USBDevice #1: Audient USB Audio ASIO Driver Manufacturer: Model UID: Audient USB Audio ASIO Driver UID: Audient USB Audio ASIO Driver
