Hello, I’m running A3.5.50 on macos 12.6.3
I downloaded an album with a variety of DSD tracks, some DSD64, DSD128, DSD256, DSD512 and one DSD1024.
When I play the DSD1024, audirvana crashes. The others work fine.
One a side note, the DSD1024 track lists a SPL.Rate of DSD1,114
I’m not sure if thats causing the crash, or if another reason. My DAC is gustard R26
I’ve attached the crash report:
Translated Report (Full Report Below)
Process: Audirvana [1004]
Path: /Applications/Audirvana.app/Contents/MacOS/Audirvana
Identifier: com.audirvana.Audirvana
Version: 3.5.50 (3580)
Code Type: X86-64 (Native)
Parent Process: launchd [1]
User ID: 501
Date/Time: 2023-03-21 17:06:33.9948 -0400
OS Version: macOS 12.6.3 (21G419)
Report Version: 12
Anonymous UUID: 09E5A248-D393-4ED9-2A0F-6B376BD5EAAF
Time Awake Since Boot: 890 seconds
System Integrity Protection: enabled
Crashed Thread: 17 Dispatch queue: com.apple.root.utility-qos
Exception Type: EXC_ARITHMETIC (SIGFPE)
Exception Codes: 0x0000000000000001, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Termination Reason: Namespace SIGNAL, Code 8 Floating point exception: 8
Terminating Process: exc handler [1004]
Thread 0:: Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x7ff81155c2be __semwait_signal + 10
1 libsystem_c.dylib 0x7ff811470863 nanosleep + 196
2 libsystem_c.dylib 0x7ff811470799 usleep + 53
3 Audirvana 0x10041a9bc 0x100000000 + 4303292
4 Audirvana 0x1001e13db 0x100000000 + 1971163
5 Audirvana 0x1005e9c2d 0x100000000 + 6200365
6 Audirvana 0x100335d0c 0x100000000 + 3366156
7 Audirvana 0x10031c936 0x100000000 + 3262774
8 Audirvana 0x100420ff4 0x100000000 + 4329460
9 Audirvana 0x10014c058 0x100000000 + 1359960
10 Audirvana 0x100420d5e 0x100000000 + 4328798
11 libdispatch.dylib 0x7ff8113df317 _dispatch_client_callout + 8
12 libdispatch.dylib 0x7ff8113ebc78 _dispatch_main_queue_drain + 943
13 libdispatch.dylib 0x7ff8113eb8bb _dispatch_main_queue_callback_4CF + 31
14 CoreFoundation 0x7ff81169af37 CFRUNLOOP_IS_SERVICING_THE_MAIN_DISPATCH_QUEUE + 9
15 CoreFoundation 0x7ff81165bfcf __CFRunLoopRun + 2771
16 CoreFoundation 0x7ff81165ae3c CFRunLoopRunSpecific + 562
17 HIToolbox 0x7ff81a30a5e6 RunCurrentEventLoopInMode + 292
18 HIToolbox 0x7ff81a30a213 ReceiveNextEventCommon + 283
19 HIToolbox 0x7ff81a30a0e5 _BlockUntilNextEventMatchingListInModeWithFilter + 70
20 AppKit 0x7ff814094fad _DPSNextEvent + 927
21 AppKit 0x7ff81409366a -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1394
22 AppKit 0x7ff814085d19 -[NSApplication run] + 586
23 AppKit 0x7ff814059c97 NSApplicationMain + 817
24 dyld 0x109c5852e start + 462
Thread 1:
0 libsystem_pthread.dylib 0x7ff811591f48 start_wqthread + 0
Thread 2:: Dispatch queue: com.apple.root.default-qos
0 libsystem_kernel.dylib 0x7ff81155c3ea __psynch_cvwait + 10
1 libsystem_pthread.dylib 0x7ff811596a6f _pthread_cond_wait + 1249
2 libc++.1.dylib 0x7ff8114f4d22 std::__1::condition_variable::wait(std::__1::unique_lockstd::__1::mutex&) + 18
3 Audirvana 0x1001e475b 0x100000000 + 1984347
4 Audirvana 0x10014c058 0x100000000 + 1359960
5 Audirvana 0x1001e44ce 0x100000000 + 1983694
6 libdispatch.dylib 0x7ff8113df317 _dispatch_client_callout + 8
7 libdispatch.dylib 0x7ff8113e19fc _dispatch_queue_override_invoke + 787
8 libdispatch.dylib 0x7ff8113eeac2 _dispatch_root_queue_drain + 343
9 libdispatch.dylib 0x7ff8113ef25c _dispatch_worker_thread2 + 160
10 libsystem_pthread.dylib 0x7ff811592f8a _pthread_wqthread + 256
11 libsystem_pthread.dylib 0x7ff811591f57 start_wqthread + 15
Thread 3:
3 Audirvana 0x100863d1b 0x100000000 + 8797467
4 libsystem_pthread.dylib 0x7ff8115964e1 _pthread_start + 125
5 libsystem_pthread.dylib 0x7ff811591f6b thread_start + 15
Thread 4:
2 Audirvana 0x1000e2c58 0x100000000 + 928856
3 Audirvana 0x1000e2913 0x100000000 + 928019
Thread 5:
2 Audirvana 0x1000e281a 0x100000000 + 927770
3 libsystem_pthread.dylib 0x7ff8115964e1 _pthread_start + 125
4 libsystem_pthread.dylib 0x7ff811591f6b thread_start + 15
Thread 6:
0 libsystem_kernel.dylib 0x7ff811561d5a __select + 10
1 Audirvana 0x1000e89c3 0x100000000 + 952771
2 Audirvana 0x1000e2913 0x100000000 + 928019
Thread 7:
Thread 8:: AMCP Logging Spool
0 libsystem_kernel.dylib 0x7ff8115599b6 semaphore_wait_trap + 10
1 caulk 0x7ff81a0962e6 caulk::mach::semaphore::wait_or_error() + 16
2 caulk 0x7ff81a07e148 caulk::concurrent::details::worker_thread::run() + 36
3 caulk 0x7ff81a07de0c void* caulk::thread_proxy<std::__1::tuple<caulk::attributes, void (caulk::concurrent::details::worker_thread::)(), std::__1::tuplecaulk::concurrent::details::worker_thread* > >(void) + 41
Thread 9:: com.apple.NSEventThread
0 libsystem_kernel.dylib 0x7ff81155997a mach_msg_trap + 10
1 libsystem_kernel.dylib 0x7ff811559ce8 mach_msg + 56
2 CoreFoundation 0x7ff81165d36d __CFRunLoopServiceMachPort + 319
3 CoreFoundation 0x7ff81165b9f8 __CFRunLoopRun + 1276
4 CoreFoundation 0x7ff81165ae3c CFRunLoopRunSpecific + 562
5 AppKit 0x7ff8142029ce _NSEventThread + 132
6 libsystem_pthread.dylib 0x7ff8115964e1 _pthread_start + 125
7 libsystem_pthread.dylib 0x7ff811591f6b thread_start + 15
Thread 10:: com.apple.CFSocket.private
1 CoreFoundation 0x7ff811684679 __CFSocketManager + 641
2 libsystem_pthread.dylib 0x7ff8115964e1 _pthread_start + 125
3 libsystem_pthread.dylib 0x7ff811591f6b thread_start + 15
Thread 11:: com.apple.audio.IOThread.client
2 CoreAudio 0x7ff8131dcc07 HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int) + 111
3 CoreAudio 0x7ff813067729 HALC_ProxyIOContext::IOWorkLoop() + 3931
4 CoreAudio 0x7ff813066205 invocation function for block in HALC_ProxyIOContext::HALC_ProxyIOContext(unsigned int, unsigned int) + 63
5 CoreAudio 0x7ff813232616 HALB_IOThread::Entry(void*) + 72
Thread 12:
Thread 13:
Thread 14:
Thread 15:
Thread 16:
Thread 17 Crashed:: Dispatch queue: com.apple.root.utility-qos
0 libdsd2pcm.dylib 0x100ebb00b dsdpcm_fir_d::run(unsigned char*, double () [9408], int) + 27
1 libdsd2pcm.dylib 0x100ebf7bf dsdpcm_converter_d::convert_internal(unsigned char, double () [9408], int) + 223
2 libdsd2pcm.dylib 0x100ebf9d6 dsdpcm_converter_d::convert(unsigned char, float*, int) + 38
3 Audirvana 0x1005cf25a 0x100000000 + 6091354
4 Audirvana 0x1003c6e06 0x100000000 + 3960326
5 Audirvana 0x10014c058 0x100000000 + 1359960
6 Audirvana 0x1003c661e 0x100000000 + 3958302
7 libdispatch.dylib 0x7ff8113df317 _dispatch_client_callout + 8
8 libdispatch.dylib 0x7ff8113eec0c _dispatch_root_queue_drain + 673
Thread 17 crashed with X86 Thread State (64-bit):
rax: 0x0000000000004972 rbx: 0x0000000117cf6000 rcx: 0x0000000000000000 rdx: 0x0000000000000000
rdi: 0x0000000117cf6030 rsi: 0x000000010ff94000 rbp: 0x000070000bcfab90 rsp: 0x000070000bcfab68
r8: 0x0000000000000000 r9: 0x0000000000000000 r10: 0x0000000100ead980 r11: 0x0000000000000000
r12: 0x0000000000000000 r13: 0x000060000000e3c0 r14: 0x0000000117f1d648 r15: 0x0000000117cf6248
rip: 0x0000000100ebb00b rfl: 0x0000000000010207 cr2: 0x0000000124d75000
Logical CPU: 3
Error Code: 0x00000000
Trap Number: 0
Thread 17 instruction stream:
89 55 b8 8b 4f 14 44 8b-4f 18 99[41]f7 f9 99 f7 .U…O.D.O…A… <==
f9 89 45 d4 85 c0 0f 8e-5b 02 00 00 44 8b 55 d4 …E…[…D.U.
31 c0 48 89 45 c8 4c 8b-5d b8 4c 89 55 a8 eb 27 1.H.E.L.].L.U…’
4c 8b 55 a8 4c 8b 5d a0-44 8b 4d c4 48 8b 55 c8 L.U.L.].D.M.H.U.
48 ff c2 49 83 c3 08 48-89 d0 48 89 55 c8 4c 39 H…I…H…H.U.L9
d2 0f 84 20 02 00 00 45-85 c9 0f 8e 70 00 00 00 … …E…p…
45 31 c0 e9 1c 00 00 00-0f 1f 84 00 00 00 00 00 E1…
8b 47 50 ff c0 99 f7 7f-0c 89 57 50 41 ff c0 45 .GP…WPA…E
39 c8 7d 4c 85 c9 0f 8e-e4 ff ff ff 31 c0 66 90 9.}L…1.f.
0f b6 0c 06 48 8b 54 c7-20 48 63 5f 50 88 0c 1a …H.T. Hc_P…
4c 8b 4c c7 20 48 63 5f-50 48 63 57 0c 48 01 da L.L. Hc_PHcW.H…
41 88 0c 11 48 ff c0 48-63 4f 14 48 39 c8 0f 8c A…H…HcO.H9…
Binary Images:
0x7ff811558000 - 0x7ff81158ffff libsystem_kernel.dylib () /usr/lib/system/libsystem_kernel.dylib
0x7ff811460000 - 0x7ff8114e8fff libsystem_c.dylib () /usr/lib/system/libsystem_c.dylib
0x100000000 - 0x100c5bfff com.audirvana.Audirvana (3.5.50) <520f4842-992e-3646-aabf-50d5528d3045> /Applications/Audirvana.app/Contents/MacOS/Audirvana
0x7ff8113dc000 - 0x7ff811422fff libdispatch.dylib () <1a04b380-76e4-3e4b-b0fc-9837533d021d> /usr/lib/system/libdispatch.dylib
0x7ff8115dd000 - 0x7ff811adffff com.apple.CoreFoundation (6.9) <93c48919-68af-367e-9a67-db4159bc962c> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7ff81a2dc000 - 0x7ff81a5cffff com.apple.HIToolbox (2.1.1) <06fdecd6-9f69-397b-b1e2-a8226c0ba7ed> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7ff814056000 - 0x7ff814ee5fff com.apple.AppKit (6.9) <11be8778-f5e5-3ccb-bcc3-10ffea3bf44b> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x109c53000 - 0x109cbefff dyld () <006a3e6f-3cd3-34d9-b0f2-ed6bd67a95a6> /usr/lib/dyld
0x7ff811590000 - 0x7ff81159bfff libsystem_pthread.dylib () /usr/lib/system/libsystem_pthread.dylib
0x7ff8114e9000 - 0x7ff811541fff libc++.1.dylib () /usr/lib/libc++.1.dylib
0x7ff81a07c000 - 0x7ff81a09dfff com.apple.audio.caulk (1.0) <8e7b3d95-1d47-3f17-9512-c5fcc30792c2> /System/Library/PrivateFrameworks/caulk.framework/Versions/A/caulk
0x7ff812ead000 - 0x7ff8135e2fff com.apple.audio.CoreAudio (5.0) <9be547d0-0af1-3470-afde-2ac4cd34441e> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x100eb8000 - 0x100ecbfff libdsd2pcm.dylib (*) <83ef7b00-ce1a-352e-968a-5e8407d69afd> /Applications/Audirvana.app/Contents/Frameworks/libdsd2pcm.dylib
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=1.2G resident=0K(0%) swapped_out_or_unallocated=1.2G(100%)
Writable regions: Total=13.5G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=13.5G(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate framework 512K 4
Activity Tracing 256K 1
CG backing stores 3840K 4
CG image 1484K 12
ColorSync 224K 27
CoreAnimation 130.3M 324
CoreGraphics 12K 2
CoreUI image data 1684K 12
Foundation 472K 6
Kernel Alloc Once 8K 1
MALLOC 402.1M 95
MALLOC guard page 32K 7
MALLOC_LARGE (reserved) 67.3M 5 reserved VM address space (unallocated)
MALLOC_NANO (reserved) 384.0M 1 reserved VM address space (unallocated)
ObjC additional data 15K 1
STACK GUARD 56.1M 18
Stack 16.6M 18
VM_ALLOCATE 896.1M 19
VM_ALLOCATE (reserved) 11.7G 3 reserved VM address space (unallocated)
__CTF 756 1
__DATA 31.0M 511
__DATA_CONST 29.9M 325
__DATA_DIRTY 1596K 206
__FONT_DATA 4K 1
__LINKEDIT 646.7M 19
__TEXT 533.5M 533
__UNICODE 592K 1
dyld private memory 1024K 1
mapped file 199.1M 33
shared memory 832K 19
TOTAL 15.0G 2210
TOTAL, minus reserved VM space 2.9G 2210
Full Report
{“app_name”:“Audirvana”,“timestamp”:“2023-03-21 17:06:34.00 -0400”,“app_version”:“3.5.50”,“slice_uuid”:“520f4842-992e-3646-aabf-50d5528d3045”,“build_version”:“3580”,“platform”:1,“bundleID”:“com.audirvana.Audirvana”,“share_with_app_devs”:1,“is_first_party”:0,“bug_type”:“309”,“os_version”:“macOS 12.6.3 (21G419)”,“incident_id”:“331A028D-EE32-4D51-8F67-CA02A175FD56”,“name”:“Audirvana”}
“uptime” : 890,
“procLaunch” : “2023-03-21 17:02:02.4862 -0400”,
“procRole” : “Foreground”,
“version” : 2,
“userID” : 501,
“deployVersion” : 210,
“modelCode” : “iMac17,1”,
“procStartAbsTime” : 619831734524,
“coalitionID” : 369,
“osVersion” : {
“train” : “macOS 12.6.3”,
“build” : “21G419”,
“releaseType” : “User”
“captureTime” : “2023-03-21 17:06:33.9948 -0400”,
“incident” : “331A028D-EE32-4D51-8F67-CA02A175FD56”,
“bug_type” : “309”,
“pid” : 1004,
“procExitAbsTime” : 891332749162,
“cpuType” : “X86-64”,
“procName” : “Audirvana”,
“procPath” : “/Applications/Audirvana.app/Contents/MacOS/Audirvana”,
“bundleInfo” : {“CFBundleShortVersionString”:“3.5.50”,“CFBundleVersion”:“3580”,“CFBundleIdentifier”:“com.audirvana.Audirvana”},
“storeInfo” : {“deviceIdentifierForVendor”:“B8379BFB-682F-5E3B-8671-995C4E1B66E2”,“thirdParty”:true},
“parentProc” : “launchd”,
“parentPid” : 1,
“coalitionName” : “com.audirvana.Audirvana”,
“crashReporterKey” : “09E5A248-D393-4ED9-2A0F-6B376BD5EAAF”,
“sip” : “enabled”,
“isCorpse” : 1,
“exception” : {“codes”:“0x0000000000000001, 0x0000000000000000”,“rawCodes”:[1,0],“type”:“EXC_ARITHMETIC”,“signal”:“SIGFPE”},
“termination” : {“flags”:0,“code”:8,“namespace”:“SIGNAL”,“indicator”:“Floating point exception: 8”,“byProc”:“exc handler”,“byPid”:1004},
“extMods” : {“caller”:{“thread_create”:0,“thread_set_state”:0,“task_for_pid”:0},“system”:{“thread_create”:0,“thread_set_state”:0,“task_for_pid”:0},“targeted”:{“thread_create”:0,“thread_set_state”:0,“task_for_pid”:0},“warnings”:0},
“faultingThread” : 17,
“threads” : [{“id”:12529,“queue”:“com.apple.main-thread”,“frames”:[{“imageOffset”:17086,“symbol”:“__semwait_signal”,“symbolLocation”:10,“imageIndex”:0},{“imageOffset”:67683,“symbol”:“nanosleep”,“symbolLocation”:196,“imageIndex”:1},{“imageOffset”:67481,“symbol”:“usleep”,“symbolLocation”:53,“imageIndex”:1},{“imageOffset”:4303292,“imageIndex”:2},{“imageOffset”:1971163,“imageIndex”:2},{“imageOffset”:6200365,“imageIndex”:2},{“imageOffset”:3366156,“imageIndex”:2},{“imageOffset”:3262774,“imageIndex”:2},{“imageOffset”:4329460,“imageIndex”:2},{“imageOffset”:1359960,“imageIndex”:2},{“imageOffset”:4328798,“imageIndex”:2},{“imageOffset”:13079,“symbol”:“_dispatch_client_callout”,“symbolLocation”:8,“imageIndex”:3},{“imageOffset”:64632,“symbol”:“_dispatch_main_queue_drain”,“symbolLocation”:943,“imageIndex”:3},{“imageOffset”:63675,“symbol”:“_dispatch_main_queue_callback_4CF”,“symbolLocation”:31,“imageIndex”:3},{“imageOffset”:778039,“symbol”:“CFRUNLOOP_IS_SERVICING_THE_MAIN_DISPATCH_QUEUE”,“symbolLocation”:9,“imageIndex”:4},{“imageOffset”:520143,“symbol”:“__CFRunLoopRun”,“symbolLocation”:2771,“imageIndex”:4},{“imageOffset”:515644,“symbol”:“CFRunLoopRunSpecific”,“symbolLocation”:562,“imageIndex”:4},{“imageOffset”:189926,“symbol”:“RunCurrentEventLoopInMode”,“symbolLocation”:292,“imageIndex”:5},{“imageOffset”:188947,“symbol”:“ReceiveNextEventCommon”,“symbolLocation”:283,“imageIndex”:5},{“imageOffset”:188645,“symbol”:“_BlockUntilNextEventMatchingListInModeWithFilter”,“symbolLocation”:70,“imageIndex”:5},{“imageOffset”:257965,“symbol”:“_DPSNextEvent”,“symbolLocation”:927,“imageIndex”:6},{“imageOffset”:251498,“symbol”:“-[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:]”,“symbolLocation”:1394,“imageIndex”:6},{“imageOffset”:195865,“symbol”:“-[NSApplication run]”,“symbolLocation”:586,“imageIndex”:6},{“imageOffset”:15511,“symbol”:“NSApplicationMain”,“symbolLocation”:817,“imageIndex”:6},{“imageOffset”:21806,“symbol”:“start”,“symbolLocation”:462,“imageIndex”:7}]},{“id”:12536,“frames”:[{“imageOffset”:8008,“symbol”:“start_wqthread”,“symbolLocation”:0,“imageIndex”:8}]},{“id”:12542,“queue”:“com.apple.root.default-qos”,“frames”:[{“imageOffset”:17386,“symbol”:“__psynch_cvwait”,“symbolLocation”:10,“imageIndex”:0},{“imageOffset”:27247,“symbol”:“_pthread_cond_wait”,“symbolLocation”:1249,“imageIndex”:8},{“imageOffset”:48418,“symbol”:“std::__1::condition_variable::wait(std::__1::unique_lockstd::__1::mutex&)”,“symbolLocation”:18,“imageIndex”:9},{“imageOffset”:1984347,“imageIndex”:2},{“imageOffset”:1359960,“imageIndex”:2},{“imageOffset”:1983694,“imageIndex”:2},{“imageOffset”:13079,“symbol”:“_dispatch_client_callout”,“symbolLocation”:8,“imageIndex”:3},{“imageOffset”:23036,“symbol”:“_dispatch_queue_override_invoke”,“symbolLocation”:787,“imageIndex”:3},{“imageOffset”:76482,“symbol”:“_dispatch_root_queue_drain”,“symbolLocation”:343,“imageIndex”:3},{“imageOffset”:78428,“symbol”:“_dispatch_worker_thread2”,“symbolLocation”:160,“imageIndex”:3},{“imageOffset”:12170,“symbol”:“_pthread_wqthread”,“symbolLocation”:256,“imageIndex”:8},{“imageOffset”:8023,“symbol”:“start_wqthread”,“symbolLocation”:15,“imageIndex”:8}]},{“id”:12551,“frames”:[{“imageOffset”:17386,“symbol”:“__psynch_cvwait”,“symbolLocation”:10,“imageIndex”:0},{“imageOffset”:27247,“symbol”:“_pthread_cond_wait”,“symbolLocation”:1249,“imageIndex”:8},{“imageOffset”:48418,“symbol”:“std::__1::condition_variable::wait(std::__1::unique_lockstd::__1::mutex&)”,“symbolLocation”:18,“imageIndex”:9},{“imageOffset”:8797467,“imageIndex”:2},{“imageOffset”:25825,“symbol”:“_pthread_start”,“symbolLocation”:125,“imageIndex”:8},{“imageOffset”:8043,“symbol”:“thread_start”,“symbolLocation”:15,“imageIndex”:8}]},{“id”:12553,“frames”:[{“imageOffset”:17386,“symbol”:“__psynch_cvwait”,“symbolLocation”:10,“imageIndex”:0},{“imageOffset”:27247,“symbol”:“_pthread_cond_wait”,“symbolLocation”:1249,“imageIndex”:8},{“imageOffset”:928856,“imageIndex”:2},{“imageOffset”:928019,“imageIndex”:2},{“imageOffset”:25825,“symbol”:“_pthread_start”,“symbolLocation”:125,“imageIndex”:8},{“imageOffset”:8043,“symbol”:“thread_start”,“symbolLocation”:15,“imageIndex”:8}]},{“id”:12554,“frames”:[{“imageOffset”:17386,“symbol”:“__psynch_cvwait”,“symbolLocation”:10,“imageIndex”:0},{“imageOffset”:27247,“symbol”:“_pthread_cond_wait”,“symbolLocation”:1249,“imageIndex”:8},{“imageOffset”:927770,“imageIndex”:2},{“imageOffset”:25825,“symbol”:“_pthread_start”,“symbolLocation”:125,“imageIndex”:8},{“imageOffset”:8043,“symbol”:“thread_start”,“symbolLocation”:15,“imageIndex”:8}]},{“id”:12557,“frames”:[{“imageOffset”:40282,“symbol”:“__select”,“symbolLocation”:10,“imageIndex”:0},{“imageOffset”:952771,“imageIndex”:2},{“imageOffset”:928019,“imageIndex”:2},{“imageOffset”:25825,“symbol”:“_pthread_start”,“symbolLocation”:125,“imageIndex”:8},{“imageOffset”:8043,“symbol”:“thread_start”,“symbolLocation”:15,“imageIndex”:8}]},{“id”:12560,“frames”:[{“imageOffset”:17386,“symbol”:“__psynch_cvwait”,“symbolLocation”:10,“imageIndex”:0},{“imageOffset”:27247,“symbol”:“_pthread_cond_wait”,“symbolLocation”:1249,“imageIndex”:8},{“imageOffset”:927770,“imageIndex”:2},{“imageOffset”:25825,“symbol”:“_pthread_start”,“symbolLocation”:125,“imageIndex”:8},{“imageOffset”:8043,“symbol”:“thread_start”,“symbolLocation”:15,“imageIndex”:8}]},{“id”:12562,“name”:“AMCP Logging Spool”,“frames”:[{“imageOffset”:6582,“symbol”:“semaphore_wait_trap”,“symbolLocation”:10,“imageIndex”:0},{“imageOffset”:107238,“symbol”:“caulk::mach::semaphore::wait_or_error()”,“symbolLocation”:16,“imageIndex”:10},{“imageOffset”:8520,“symbol”:“caulk::concurrent::details::worker_thread::run()”,“symbolLocation”:36,“imageIndex”:10},{“imageOffset”:7692,“symbol”:“void* caulk::thread_proxy<std::__1::tuple<caulk::attributes, void (caulk::concurrent::details::worker_thread::)(), std::__1::tuplecaulk::concurrent::details::worker_thread* > >(void)”,“symbolLocation”:41,“imageIndex”:10},{“imageOffset”:25825,“symbol”:“_pthread_start”,“symbolLocation”:125,“imageIndex”:8},{“imageOffset”:8043,“symbol”:“thread_start”,“symbolLocation”:15,“imageIndex”:8}]},{“id”:12580,“name”:“com.apple.NSEventThread”,“frames”:[{“imageOffset”:6522,“symbol”:“mach_msg_trap”,“symbolLocation”:10,“imageIndex”:0},{“imageOffset”:7400,“symbol”:“mach_msg”,“symbolLocation”:56,“imageIndex”:0},{“imageOffset”:525165,“symbol”:“__CFRunLoopServiceMachPort”,“symbolLocation”:319,“imageIndex”:4},{“imageOffset”:518648,“symbol”:“__CFRunLoopRun”,“symbolLocation”:1276,“imageIndex”:4},{“imageOffset”:515644,“symbol”:“CFRunLoopRunSpecific”,“symbolLocation”:562,“imageIndex”:4},{“imageOffset”:1755598,“symbol”:“_NSEventThread”,“symbolLocation”:132,“imageIndex”:6},{“imageOffset”:25825,“symbol”:“_pthread_start”,“symbolLocation”:125,“imageIndex”:8},{“imageOffset”:8043,“symbol”:“thread_start”,“symbolLocation”:15,“imageIndex”:8}]},{“id”:12581,“name”:“com.apple.CFSocket.private”,“frames”:[{“imageOffset”:40282,“symbol”:“__select”,“symbolLocation”:10,“imageIndex”:0},{“imageOffset”:685689,“symbol”:“__CFSocketManager”,“symbolLocation”:641,“imageIndex”:4},{“imageOffset”:25825,“symbol”:“_pthread_start”,“symbolLocation”:125,“imageIndex”:8},{“imageOffset”:8043,“symbol”:“thread_start”,“symbolLocation”:15,“imageIndex”:8}]},{“id”:12774,“name”:“com.apple.audio.IOThread.client”,“frames”:[{“imageOffset”:6522,“symbol”:“mach_msg_trap”,“symbolLocation”:10,“imageIndex”:0},{“imageOffset”:7400,“symbol”:“mach_msg”,“symbolLocation”:56,“imageIndex”:0},{“imageOffset”:3341319,“symbol”:“HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int)”,“symbolLocation”:111,“imageIndex”:11},{“imageOffset”:1812265,“symbol”:“HALC_ProxyIOContext::IOWorkLoop()”,“symbolLocation”:3931,“imageIndex”:11},{“imageOffset”:1806853,“symbol”:“invocation function for block in HALC_ProxyIOContext::HALC_ProxyIOContext(unsigned int, unsigned int)”,“symbolLocation”:63,“imageIndex”:11},{“imageOffset”:3692054,“symbol”:“HALB_IOThread::Entry(void*)”,“symbolLocation”:72,“imageIndex”:11},{“imageOffset”:25825,“symbol”:“_pthread_start”,“symbolLocation”:125,“imageIndex”:8},{“imageOffset”:8043,“symbol”:“thread_start”,“symbolLocation”:15,“imageIndex”:8}]},{“id”:12788,“frames”:[{“imageOffset”:8008,“symbol”:“start_wqthread”,“symbolLocation”:0,“imageIndex”:8}]},{“id”:12789,“frames”:[{“imageOffset”:8008,“symbol”:“start_wqthread”,“symbolLocation”:0,“imageIndex”:8}]},{“id”:12797,“frames”:[{“imageOffset”:17386,“symbol”:“__psynch_cvwait”,“symbolLocation”:10,“imageIndex”:0},{“imageOffset”:27247,“symbol”:“_pthread_cond_wait”,“symbolLocation”:1249,“imageIndex”:8},{“imageOffset”:927770,“imageIndex”:2},{“imageOffset”:25825,“symbol”:“_pthread_start”,“symbolLocation”:125,“imageIndex”:8},{“imageOffset”:8043,“symbol”:“thread_start”,“symbolLocation”:15,“imageIndex”:8}]},{“id”:12799,“frames”:[{“imageOffset”:17386,“symbol”:“__psynch_cvwait”,“symbolLocation”:10,“imageIndex”:0},{“imageOffset”:27247,“symbol”:“_pthread_cond_wait”,“symbolLocation”:1249,“imageIndex”:8},{“imageOffset”:927770,“imageIndex”:2},{“imageOffset”:25825,“symbol”:“_pthread_start”,“symbolLocation”:125,“imageIndex”:8},{“imageOffset”:8043,“symbol”:“thread_start”,“symbolLocation”:15,“imageIndex”:8}]},{“id”:14607,“frames”:[{“imageOffset”:8008,“symbol”:“start_wqthread”,“symbolLocation”:0,“imageIndex”:8}]},{“triggered”:true,“id”:14608,“instructionState”:{“instructionStream”:{“bytes”:[137,85,184,139,79,20,68,139,79,24,153,65,247,249,153,247,249,137,69,212,133,192,15,142,91,2,0,0,68,139,85,212,49,192,72,137,69,200,76,139,93,184,76,137,85,168,235,39,76,139,85,168,76,139,93,160,68,139,77,196,72,139,85,200,72,255,194,73,131,195,8,72,137,208,72,137,85,200,76,57,210,15,132,32,2,0,0,69,133,201,15,142,112,0,0,0,69,49,192,233,28,0,0,0,15,31,132,0,0,0,0,0,139,71,80,255,192,153,247,127,12,137,87,80,65,255,192,69,57,200,125,76,133,201,15,142,228,255,255,255,49,192,102,144,15,182,12,6,72,139,84,199,32,72,99,95,80,136,12,26,76,139,76,199,32,72,99,95,80,72,99,87,12,72,1,218,65,136,12,17,72,255,192,72,99,79,20,72,57,200,15,140],“offset”:11}},“threadState”:{“r13”:{“value”:105553116324800},“rax”:{“value”:18802},“rflags”:{“value”:66055},“cpu”:{“value”:3},“r14”:{“value”:4696692296},“rsi”:{“value”:4562960384},“r8”:{“value”:0},“cr2”:{“value”:4913057792},“rdx”:{“value”:0},“r10”:{“value”:4310358400},“r9”:{“value”:0},“r15”:{“value”:4694434376},“rbx”:{“value”:4694433792},“trap”:{“value”:0},“err”:{“value”:0},“r11”:{“value”:0},“rip”:{“value”:4310413323,“matchesCrashFrame”:1},“rbp”:{“value”:123145500470160},“rsp”:{“value”:123145500470120},“r12”:{“value”:0},“rcx”:{“value”:0},“flavor”:“x86_THREAD_STATE”,“rdi”:{“value”:4694433840}},“queue”:“com.apple.root.utility-qos”,“frames”:[{“imageOffset”:12299,“symbol”:“dsdpcm_fir_d::run(unsigned char*, double () [9408], int)",“symbolLocation”:27,“imageIndex”:12},{“imageOffset”:30655,“symbol”:"dsdpcm_converter_d::convert_internal(unsigned char, double () [9408], int)",“symbolLocation”:223,“imageIndex”:12},{“imageOffset”:31190,“symbol”:"dsdpcm_converter_d::convert(unsigned char, float*, int)”,“symbolLocation”:38,“imageIndex”:12},{“imageOffset”:6091354,“imageIndex”:2},{“imageOffset”:3960326,“imageIndex”:2},{“imageOffset”:1359960,“imageIndex”:2},{“imageOffset”:3958302,“imageIndex”:2},{“imageOffset”:13079,“symbol”:“_dispatch_client_callout”,“symbolLocation”:8,“imageIndex”:3},{“imageOffset”:76812,“symbol”:“_dispatch_root_queue_drain”,“symbolLocation”:673,“imageIndex”:3},{“imageOffset”:78428,“symbol”:“_dispatch_worker_thread2”,“symbolLocation”:160,“imageIndex”:3},{“imageOffset”:12170,“symbol”:“_pthread_wqthread”,“symbolLocation”:256,“imageIndex”:8},{“imageOffset”:8023,“symbol”:“start_wqthread”,“symbolLocation”:15,“imageIndex”:8}]}],
“usedImages” : [
“source” : “P”,
“arch” : “x86_64”,
“base” : 140703419432960,
“size” : 229376,
“uuid” : “e2477724-bccf-3a8c-9c75-c774c569f36e”,
“path” : “/usr/lib/system/libsystem_kernel.dylib”,
“name” : “libsystem_kernel.dylib”
“source” : “P”,
“arch” : “x86_64”,
“base” : 140703418417152,
“size” : 561152,
“uuid” : “e42e9d7a-03b4-340b-b61e-dcd45fd4acc0”,
“path” : “/usr/lib/system/libsystem_c.dylib”,
“name” : “libsystem_c.dylib”
“source” : “P”,
“arch” : “x86_64”,
“base” : 4294967296,
“CFBundleShortVersionString” : “3.5.50”,
“CFBundleIdentifier” : “com.audirvana.Audirvana”,
“size” : 12959744,
“uuid” : “520f4842-992e-3646-aabf-50d5528d3045”,
“path” : “/Applications/Audirvana.app/Contents/MacOS/Audirvana”,
“name” : “Audirvana”,
“CFBundleVersion” : “3580”
“source” : “P”,
“arch” : “x86_64”,
“base” : 140703417876480,
“size” : 290816,
“uuid” : “1a04b380-76e4-3e4b-b0fc-9837533d021d”,
“path” : “/usr/lib/system/libdispatch.dylib”,
“name” : “libdispatch.dylib”
“source” : “P”,
“arch” : “x86_64h”,
“base” : 140703419977728,
“CFBundleShortVersionString” : “6.9”,
“CFBundleIdentifier” : “com.apple.CoreFoundation”,
“size” : 5255168,
“uuid” : “93c48919-68af-367e-9a67-db4159bc962c”,
“path” : “/System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation”,
“name” : “CoreFoundation”,
“CFBundleVersion” : “1866”
“source” : “P”,
“arch” : “x86_64”,
“base” : 140703567822848,
“CFBundleShortVersionString” : “2.1.1”,
“CFBundleIdentifier” : “com.apple.HIToolbox”,
“size” : 3096576,
“uuid” : “06fdecd6-9f69-397b-b1e2-a8226c0ba7ed”,
“path” : “/System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox”,
“name” : “HIToolbox”
“source” : “P”,
“arch” : “x86_64”,
“base” : 140703464513536,
“CFBundleIdentifier” : “com.apple.AppKit”,
“size” : 15269888,
“uuid” : “11be8778-f5e5-3ccb-bcc3-10ffea3bf44b”,
“path” : “/System/Library/Frameworks/AppKit.framework/Versions/C/AppKit”,
“name” : “AppKit”,
“CFBundleVersion” : “2113.60.148”
“source” : “P”,
“arch” : “x86_64”,
“base” : 4458885120,
“size” : 442368,
“uuid” : “006a3e6f-3cd3-34d9-b0f2-ed6bd67a95a6”,
“path” : “/usr/lib/dyld”,
“name” : “dyld”
“source” : “P”,
“arch” : “x86_64”,
“base” : 140703419662336,
“size” : 49152,
“uuid” : “b5454e27-e8c7-3fdb-b77f-714f1e82e70b”,
“path” : “/usr/lib/system/libsystem_pthread.dylib”,
“name” : “libsystem_pthread.dylib”
“source” : “P”,
“arch” : “x86_64”,
“base” : 140703418978304,
“size” : 364544,
“uuid” : “a031469a-a9fe-37e0-8523-4f80351ea635”,
“path” : “/usr/lib/libc++.1.dylib”,
“name” : “libc++.1.dylib”
“source” : “P”,
“arch” : “x86_64”,
“base” : 140703565332480,
“CFBundleShortVersionString” : “1.0”,
“CFBundleIdentifier” : “com.apple.audio.caulk”,
“size” : 139264,
“uuid” : “8e7b3d95-1d47-3f17-9512-c5fcc30792c2”,
“path” : “/System/Library/PrivateFrameworks/caulk.framework/Versions/A/caulk”,
“name” : “caulk”
“source” : “P”,
“arch” : “x86_64”,
“base” : 140703445995520,
“CFBundleShortVersionString” : “5.0”,
“CFBundleIdentifier” : “com.apple.audio.CoreAudio”,
“size” : 7561216,
“uuid” : “9be547d0-0af1-3470-afde-2ac4cd34441e”,
“path” : “/System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio”,
“name” : “CoreAudio”,
“CFBundleVersion” : “5.0”
“source” : “P”,
“arch” : “x86_64”,
“base” : 4310401024,
“size” : 81920,
“uuid” : “83ef7b00-ce1a-352e-968a-5e8407d69afd”,
“path” : “/Applications/Audirvana.app/Contents/Frameworks/libdsd2pcm.dylib”,
“name” : “libdsd2pcm.dylib”
“sharedCache” : {
“base” : 140703416406016,
“size” : 19331678208,
“uuid” : “b6d97ead-9d19-3228-adaa-cca8452c02d2”
“vmSummary” : “ReadOnly portion of Libraries: Total=1.2G resident=0K(0%) swapped_out_or_unallocated=1.2G(100%)\nWritable regions: Total=13.5G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=13.5G(100%)\n\n VIRTUAL REGION \nREGION TYPE SIZE COUNT (non-coalesced) \n=========== ======= ======= \nAccelerate framework 512K 4 \nActivity Tracing 256K 1 \nCG backing stores 3840K 4 \nCG image 1484K 12 \nColorSync 224K 27 \nCoreAnimation 130.3M 324 \nCoreGraphics 12K 2 \nCoreUI image data 1684K 12 \nFoundation 472K 6 \nKernel Alloc Once 8K 1 \nMALLOC 402.1M 95 \nMALLOC guard page 32K 7 \nMALLOC_LARGE (reserved) 67.3M 5 reserved VM address space (unallocated)\nMALLOC_NANO (reserved) 384.0M 1 reserved VM address space (unallocated)\nObjC additional data 15K 1 \nSTACK GUARD 56.1M 18 \nStack 16.6M 18 \nVM_ALLOCATE 896.1M 19 \nVM_ALLOCATE (reserved) 11.7G 3 reserved VM address space (unallocated)\n__CTF 756 1 \n__DATA 31.0M 511 \n__DATA_CONST 29.9M 325 \n__DATA_DIRTY 1596K 206 \n__FONT_DATA 4K 1 \n__LINKEDIT 646.7M 19 \n__TEXT 533.5M 533 \n__UNICODE 592K 1 \ndyld private memory 1024K 1 \nmapped file 199.1M 33 \nshared memory 832K 19 \n=========== ======= ======= \nTOTAL 15.0G 2210 \nTOTAL, minus reserved VM space 2.9G 2210 \n”,
“legacyInfo” : {
“threadTriggered” : {
“queue” : “com.apple.root.utility-qos”
“trialInfo” : {
“rollouts” : [
“rolloutId” : “5fb4245a1bbfe8005e33a1e1”,
“factorPackIds” : {
"deploymentId" : 240000021
"rolloutId" : "5f72dc58705eff005a46b3a9",
"factorPackIds" : {
"deploymentId" : 240000015
“experiments” : [
Model: iMac17,1, BootROM 170.0.0.0.0, 4 processors, Quad-Core Intel Core i5, 3.2 GHz, 24 GB, SMC 2.33f12
Graphics: AMD Radeon R9 M390, AMD Radeon R9 M390, PCIe, 2 GB
Display: iMac, Retina 5K (5120 x 2880), Main, MirrorOff, Online
Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1867 MHz, 0x80AD, 0x484D54343531533642465238412D52442020
Memory Module: BANK 0/DIMM1, 8 GB, DDR3, 1867 MHz, 0x85F7, 0x48363431475536374733313836470000
Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1867 MHz, 0x80AD, 0x484D54343531533642465238412D52442020
Memory Module: BANK 1/DIMM1, 8 GB, DDR3, 1867 MHz, 0x85F7, 0x48363431475536374733313836470000
AirPort: spairport_wireless_card_type_wifi (0x14E4, 0x14A), Broadcom BCM43xx 1.0 (7.77.111.1 AirPortDriverBrcmNIC-1710.4)
AirPort:
Bluetooth: Version (null), 0 services, 0 devices, 0 incoming serial ports
Network Service: Wi-Fi, AirPort, en1
Serial ATA Device: APPLE SSD SM0256G, 251 GB
USB Device: USB30Bus
USB Device: My Book 25EE
USB Device: 4-Port USB 3.0 Hub
USB Device: My Book 1230
USB Device: 4-Port USB 2.0 Hub
USB Device: USB 2.0 Hub [MTT]
USB Device: ImageMate 8 in 1
USB Device: LE850G
USB Device: Bluetooth USB Host Controller
USB Device: FaceTime HD Camera (Built-in)
USB Device: Gustard USB Audio 2.0
Thunderbolt Bus: iMac, Apple Inc., 28.1
