It’s coming to the end of my trial and need to make a decision.
I like the software and total experience after my initial problems but one remains.
If I try to skip a track or select another track I get an error message saying programme has unexpectedly exited and it will shut down. It will do this numerous times during a listening session. I am running Windows 10 Pro 64 bit with 16gb ram, any ideas please ?
Hello @MarkR,
Can you take a look at your log file form Audirvana to see if there is errors in it?
Hello Damien,
Couldn’t seem to find location of files so bit the bullet and paid for full licence. Only been using for last 5 minutes but all issues when skipping and selecting tracks has gone. It now selects tracks without a very long pause and is not crashing at the minute. If it remains like this i’ll be happy. All I have done is registered the activation code.
Mark
10 minutes in and it is a completely different user experience now. Very happy at the minute, don’t know why it is different once fully registered but it really is, nearly didn’t purchase it but glad I did.
Mark
If you encounter the same issue during the use of Audirvana feel free to send a message here
Will do and thanks !!
