Hi! I cannot find the Audirvana Database with the new Apple Big Sur. I cannot find the folder: Users/…/Library/ApplicationSupport/Audirvana…
I’ve tried a search for Audirvana and only shows the app.
I need to replace the database because it seems to be corrupt.
I’m using a MacMini.
Thanks for any help.
Hey leohifi,
On the Finder menu, click on the Go Menu/Go to Folder and enter this exactly as it is posted here:
~/library/applicationsupport/audirvana
Scroll up to ApplicationsSupport double click it and select Audirvana folder and double click it. You should find your Audirvana database there!
Good luck - scottw50
Thanks a lot for the help, scottw50. It worked out great. Thanks, again.
