Hello, Audirvana does not detect the Arcam SA 30 as a full MQA decoder. It is.The forum will not allow me to paste the debug information…
Ken
Ken
You can set it manually to MQA decoder.
Ya it didn’t auto-detect my SMSL M400, but you can manually set it and MQA will pass just fine.
I did set it manually. Does not work. This is a Upnp connection via ethernet. I’ve tried everything. I can set it as a renderer and Audirvana will unfold the first layer and pass that. But when set as a MQA decoder, it sends 24/48 to the Arcam and the Arcam does not see the MQA stream.
Have you disabled the auto detect feature? Are you on a Mac or a PC?
Yes I have tried that. I once had to do that with a Meridian Employer II a few versions back. I have been using Audirvana for many years. The Arcam SA 30 is the new piece of the puzzle. And I have always used USB, not Upnp. I am using a MacBook running the latest Catalina. I can’t post the debug because I am a new poster on the forum. Its been a long time since I needed help with Audirvana!
Ken
It looks like the MQA is supported only when streamed directly from the internet and from files on USB drive.
Check that with the manufacturer.
No, I get MQA over ethernet with Tidal via Roon.
Hello @kenkirk, I changed your account settings in the forum, you should now be able to post the debug info.
here is the debug : Thanks!
Audirvana Mac Version 3.5.40 (3570)
macOS 10.15.6 with 8192MB RAM
Registered to Kenneth Kirkpatrick
Per track: OFF
AUTO: /Users/kenkirk/Music
Library database path: /Users/kenkirk/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Preferred device: Stereo room speaker Model UID:Harman Luxury Audio Stereo room speaker UID:uuid:01e7c5cc-dde0-4813-8668-2b215e0ac87c
Currently playing to UPnP device at 24 bits 48kHz
UPnP device at http://10.0.0.5:40463/01e7c5cc-dde0-4813-8668-2b215e0ac87c.xml
ID 0x0 Stereo room speaker Manufacturer:Harman Luxury Audio
Volume control: No
DSD capability: Raw DSD (MSB)
http-get::audio/aac:
http-get::audio/wave:
http-get::audio/flac:
http-get::audio/m4a:
http-get::application/ogg:
http-get::audio/wav:
http-get::audio/x-m4a:
http-get::audio/x-dsf:
http-get::audio/x-wav:
http-get::audio/mpeg:
http-get::audio/aiff:
http-get::audio/x-flac:
http-get::audio/ogg:
http-get::audio/vorbis:
http-get::text/xml:
http-get::audio/x-dff:
http-get::audio/x-aiff:
rtsp-rtp-udp::audio/aac:
rtsp-rtp-udp::audio/wave:
rtsp-rtp-udp::audio/flac:
rtsp-rtp-udp::audio/m4a:
rtsp-rtp-udp::audio/wav:
rtsp-rtp-udp::audio/x-m4a:
rtsp-rtp-udp::audio/x-dsf:
rtsp-rtp-udp::audio/x-wav:
rtsp-rtp-udp::audio/aiff:
rtsp-rtp-udp::audio/x-flac:
rtsp-rtp-udp::audio/ogg:
rtsp-rtp-udp::audio/vorbis:
rtsp-rtp-udp::audio/x-dff:
rtsp-rtp-udp::audio/x-aiff:
DLNA 1.5: Yes
Gapless playback: Yes
Can play native DSD: Yes
12 virtual formats:
0 physical formats
NrTracks: 1
MediaDuration: 0:04:14
CurrentURI: http://10.0.0.3:49152/audirvana/audio_0_0.mqa.wav
CurrentURIMetadata:
dc:titleR. Strauss: Ein Heldenleben, Op.40, TrV 190 - Der Held</dc:title>
dc:creatorBerliner Philharmoniker</dc:creator>
upnp:artistBerliner Philharmoniker</upnp:artist>
upnp:genre</upnp:genre>
upnp:albumArtURIhttp://resources.tidal.com/images/ca52ae50/3345/4712/813f/756fa138bfe8/640x640.jpg</upnp:albumArtURI>
upnp:albumStrauss, R.: Ein Heldenleben, Op. 40, TrV 190 / Wagner: Siegfried-Idyll, WWV 103</upnp:album>
nextURI: http://10.0.0.3:49152/audirvana/audio_1_1.mqa.wav
1
object.item.audioItem.musicTrack
PlayMedium: NETWORK
<?xml version="1.0"?> 1 0 SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetMediaInfo_Ext InstanceID in A_ARG_TYPE_InstanceID CurrentType out CurrentMediaCategory NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActions GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Stop InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID X_DLNA_GetBytePositionInfo InstanceID in A_ARG_TYPE_InstanceID TrackSize out X_DLNA_CurrentTrackSize RelByte out X_DLNA_RelativeBytePosition AbsByte out X_DLNA_AbsoluteBytePosition SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode TransportState string STOPPED PAUSED_PLAYBACK PAUSED_RECORDING PLAYING RECORDING TRANSITIONING NO_MEDIA_PRESENT TransportStatus string OK ERROR_OCCURRED CurrentMediaCategory string NO_MEDIA TRACK_AWARE TRACK_UNAWARE CurrentTransportActions string PlaybackStorageMedium string UNKNOWN DV MINI-DV VHS W-VHS S-VHS D-VHS VHSC VIDEO8 HI8 CD-ROM CD-DA CD-R CD-RW VIDEO-CD SACD MD-AUDIO MD-PICTURE DVD-ROM DVD-VIDEO DVD-R DVD+RW DVD-RW DVD-RAM DVD-AUDIO DAT LD HDD MICRO-MV NETWORK NONE NOT_IMPLEMENTED SD PC-CARD MMC CF BD MS HD_DVD RecordStorageMedium string UNKNOWN DV MINI-DV VHS W-VHS S-VHS D-VHS VHSC VIDEO8 HI8 CD-ROM CD-DA CD-R CD-RW VIDEO-CD SACD MD-AUDIO MD-PICTURE DVD-ROM DVD-VIDEO DVD-R DVD+RW DVD-RW DVD-RAM DVD-AUDIO DAT LD HDD MICRO-MV NETWORK NONE NOT_IMPLEMENTED SD PC-CARD MMC CF BD MS HD_DVD PossiblePlaybackStorageMedia string NONE NETWORK PossibleRecordStorageMedia string CurrentPlayMode string NORMAL REPEAT_TRACK REPEAT_ONE REPEAT_ALL NORMAL TransportPlaySpeed string 1 1 RecordMediumWriteStatus string WRITABLE PROTECTED NOT_WRITABLE UNKNOWN NOT_IMPLEMENTED CurrentRecordQualityMode string 0:EP 1:LP 2:SP 0:BASIC 1:MEDIUM 2:HIGH NOT_IMPLEMENTED PossibleRecordQualityModes string NumberOfTracks ui4 0 512 CurrentTrack ui4 0 512 1 CurrentTrackDuration string CurrentMediaDuration string CurrentTrackMetaData string CurrentTrackURI string AVTransportURI string AVTransportURIMetaData string NextAVTransportURI string NextAVTransportURIMetaData string RelativeTimePosition string AbsoluteTimePosition string RelativeCounterPosition i4 AbsoluteCounterPosition i4 LastChange string A_ARG_TYPE_SeekMode string ABS_TIME REL_TIME TRACK_NR ABS_COUNT REL_COUNT X_DLNA_REL_BYTE A_ARG_TYPE_SeekTarget string A_ARG_TYPE_InstanceID ui4 X_DLNA_RelativeBytePosition string X_DLNA_AbsoluteBytePosition string X_DLNA_CurrentTrackSize stringCurrent device RootDevice description:
<?xml version="1.0"?> 1 0 QPlay:2.1 urn:schemas-upnp-org:device:MediaRenderer:1 Stereo room speaker Harman Luxury Audio http://www.arcam.co.uk/ ARCAM SA30 http://www.arcam.co.uk/ 50236f78-e639-470c-8d27-cde20aa67c2f uuid:01e7c5cc-dde0-4813-8668-2b215e0ac87c image/png 120 120 24 /LibRygelRenderer-120x120x24.png image/png 48 48 24 /LibRygelRenderer-48x48x24.png image/jpeg 120 120 24 /LibRygelRenderer-120x120x24.jpg image/jpeg 48 48 24 /LibRygelRenderer-48x48x24.jpg urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /xml/ConnectionManager.xml /Control/LibRygelRenderer/RygelSinkConnectionManager /Event/LibRygelRenderer/RygelSinkConnectionManager urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /xml/AVTransport2.xml /Control/LibRygelRenderer/RygelAVTransport /Event/LibRygelRenderer/RygelAVTransport urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /xml/RenderingControl2.xml /Control/LibRygelRenderer/RygelRenderingControl /Event/LibRygelRenderer/RygelRenderingControl urn:schemas-tencent-com:service:QPlay:1 urn:tencent-com:serviceId:QPlay /xml/QPlayDescription.xml /Control/LibRygelRenderer/QPlay /Event/LibRygelRenderer/QPlay http://10.0.0.5:80/ DMR-1.51 5000 "Stimuli;Filtering"UPnP devices found : 4
Device #0: ID 0x0 Arcam 58ff68 UID: uuid:3dcc7100-f76c-11dd-87af-00226158ff68 Location: http://10.0.0.18:8080/dd.xml
Device #1: ID 0x0 Stereo room speaker UID: uuid:01e7c5cc-dde0-4813-8668-2b215e0ac87c Location: http://10.0.0.5:40463/01e7c5cc-dde0-4813-8668-2b215e0ac87c.xml
Device #2: ID 0x0 TMM RVU Client MediaRenderer UID: uuid:MediaRenderer-70_5A_9E_2A_43_43 Location: http://169.254.5.112:63445/upnp/xml/devices/MediaRenderer1.xml
Device #3: ID 0x0 TMM RVU Client MediaRenderer UID: uuid:MediaRenderer-CC_03_FA_F3_A0_DA Location: http://169.254.12.147:63445/upnp/xml/devices/MediaRenderer1.xml
Device #0: ID 0x30 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:93 UID: AppleHDAEngineOutput:1B,0,1,1:0
So you set your Arcam as Decoder, MQA is not automatically detectable over UPnP, this is why you need to set it manually, when you play a MQA file in Audirvana, does your Arcam detect it?
Yes I set the Arcam SA 30 as a MQA decoder. Audirvana shows the track from Tidal as a MQA, blue dot, 24/192 etc, but on the right side of the screen at output it shows 24/48 and that is what the Arcam shows. The Arcam receives the track name information and plays the track, but at 24/48 and no MQA.
You need to contact Arcam about it because this means your DAC do not detect MQA content over UPnP. This is what Audirvana send to your device:
It works perfect with Roon. Is Roon set up differently??
Roon is not using UPnP, they use a proprietary protocol that is very similar to it but it’s not UPnP.
ok, thanks! I will contact Arcam support.
Ken
Arcam SA30 supports MQA via uPnP when using mConnect as a controller on an Android phone. Of course, Arcam displays correct information about parameters of MQA stream. Unfortunately, Audirvana behaves as if the device does not support MQA at all.
Best regards,
Maciej
Hello @maciekb, you need to change the MQA settings in the audio output settings to MQA Decoder so Audirvana can send to your SA30 the MQA stream directly.
