I am running Audirvāna Studio on aniMac, connected to. PS Audio Direct Stream DAC. The sound is great but I am continuing to have troubles with Audirvāna dropping out. Today I tried playing music from my local disk, from Qobuz and Tidal as well as Radio Paradise that I listen to a lot. However on all these sources Audirvāna would drop out before the first track had completed. I have had some advice a few weeks ago from Audirvāna but this hasn’t resolved my issue. I also have Roon which does not drop out. I prefer the Audirvāna sound but don’t want to keep using it if it keeps needing to be re started. Does anybody else have a similar issue?
Can you paste the debug info here?
This is the debug info about 2 seconds after Radio Paradise cut out.
Audirvana Studio 2.2.2 (20202)
macOS Version 13.1 (Build 22C65) with 8GB physical RAM
Connected account of : Ben Searle
Per track: OFF
AUTO: /Volumes/Music/Music
Library database path: /Users/ben/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 50018
Active method: UPnP
Preferred device: [UPnP] BridgeIIInputROY Model UID:PS Audio DirectStream DAC UID:uuid:3A5BCA42-1F56-124A-BFEF-985E1B7E50DA
Selected device:BridgeIIInputROY
Manufacturer: PS Audio
Model name: DirectStream DAC
Model UID: PS Audio DirectStream DAC
UID: uuid:3A5BCA42-1F56-124A-BFEF-985E1B7E50DA
UPnP device at http://192.168.0.108:38400/description.xml
ID 0x0
Volume control: Yes
UPnP set capabilities
Maximum PCM bitdepth set: 24
Not native DSD capable
Avoid RAW PCM streams: Yes
http-get::audio/mpeg:dlna.org_pn=mp3
http-get::audio/mp4:dlna.org_pn=mp4
http-get::audio/vnd.dlna.adts:dlna.org_pn=aac_adts
http-get::audio/x-ms-wma:dlna.org_pn=wmabase
http-get::audio/x-ms-wma:dlna.org_pn=wmafull
http-get::audio/x-ms-wma:dlna.org_pn=wmapro
http-get::audio/x-ms-wma:dlna.org_pn=wmalsl
http-get::audio/x-sony-oma:dlna.org_pn=atrac3plus
http-get::audio/aiff:
http-get::audio/wav:
http-get::audio/flac:
http-get::audio/aac:
http-get::audio/m4a:
http-get::audio/ac3:
http-get::audio/x-dsf:
http-get::audio/x-wav:
DLNA 1.5: Yes
Native Gapless playback: Yes
Universal Gapless playback active: Yes
Missing events workaround: No
Can play native DSD: No
Volume Control: dB
12 virtual formats:
0 physical formats
NrTracks: 0
MediaDuration: 0:00:00
CurrentURI:
CurrentURIMetadata:
nextURI:
nextURIMetadata:
PlayMedium: NONE
Current transport actions:
Play
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:MediaRenderer:1 BridgeIIInputROY PS Audio http://www.conversdigital.com This model is a connected audio module which supports the UPnP/DLNA standard specification. DirectStream DAC CDMCM-210-001 uuid:3A5BCA42-1F56-124A-BFEF-985E1B7E50DA http://www.conversdigital.com DMR-1.50 image/png 48 48 24 /images/small.png image/png 120 120 24 /images/large.png image/jpeg 48 48 24 /images/small.jpg image/jpeg 120 120 24 /images/large.jpg urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /service/RenderingControl1.xml /service/RenderingControl_control /service/RenderingControl_event urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /service/ConnectionManager1.xml /service/ConnectionManager_control /service/ConnectionManager_event urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /service/AVTransport1.xml /service/AVTransport_control /service/AVTransport_event http://192.168.0.108:38400Current device RootDevice description:
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:MediaRenderer:1 BridgeIIInputROY PS Audio http://www.conversdigital.com This model is a connected audio module which supports the UPnP/DLNA standard specification. DirectStream DAC CDMCM-210-001 uuid:3A5BCA42-1F56-124A-BFEF-985E1B7E50DA http://www.conversdigital.com DMR-1.50 image/png 48 48 24 /images/small.png image/png 120 120 24 /images/large.png image/jpeg 48 48 24 /images/small.jpg image/jpeg 120 120 24 /images/large.jpg urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /service/RenderingControl1.xml /service/RenderingControl_control /service/RenderingControl_event urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /service/ConnectionManager1.xml /service/ConnectionManager_control /service/ConnectionManager_event urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /service/AVTransport1.xml /service/AVTransport_control /service/AVTransport_event http://192.168.0.108:38400UPnP devices found : 2
Device #0: ID 0x0 : BridgeIIInputROY
Device #1: ID 0x0 : TV
UID: uuid:23456789-1234-1010-8000-38184CE86F85
Manufacturer: Sony Corporation
Model name: MediaRenderer
Max. memory for audio buffers: 1222MB
Local Audio Engine: CoreAudio
Device #0: ID 0x53 Built-in Output
Model UID: AppleHDA:14
UID: AppleHDAEngineOutput:1F,3,0,1,1:0
Device #1: ID 0x30 Microsoft Teams Audio
Manufacturer: Microsoft Corp.
Chromecast devices found : 1
Device #0: TV
Model name: BRAVIA 4K UR2
I have just been playing some albums from both Tidal and Qobuz and they stop after a couple of minutes.
I have also upgraded to 2.2.3. It’s very frustrating.
Hello @Ben54 ,
Your device states it is gapless, can you remove the Universal Gapless playback you activated in the audio output settings if Audirvāna and try to reproduce your issue?
Also reduce the pre-load cache to 4000MB.
I have tried the suggestions provided above and while there has been some success, when I change from Radio to my local albums and then to Qobuz or Tidal I am getting only one track of an album plying then it stops. I have attached a debug report taken just after the last stoppage from a Qobuz playlist.
Audirvana Studio 2.2.3 (20203)
Per track: OFF
Listening on 127.0.0.1 on port 49213
Active method: UPnP
Currently playing to UPnP device at 24 bits 96kHz
UPnP device at http://192.168.0.12:38400/description.xml
ID 0x0
Volume control: Yes
DLNA 1.5: Yes
Volume Control: dB
12 virtual formats:
0 physical formats
NrTracks: 0
CurrentURI:
CurrentURIMetadata:
nextURI: http://192.168.0.16:49152/audirvana/audio_165.wav
nextURIMetadata:
dc:titleSun Is Shining (Album Version)</dc:title>
dc:creatorBob Marley & The Wailers</dc:creator>
upnp:artistBob Marley & The Wailers</upnp:artist>
upnp:genreReggae</upnp:genre>
upnp:albumArtURIhttp://static.qobuz.com/images/covers/59/98/0060253729859_600.jpg</upnp:albumArtURI>
upnp:albumKaya</upnp:album>
upnp:originalTrackNumber4</upnp:originalTrackNumber>
PlayMedium: NONE
Play
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:MediaRenderer:1 BridgeIIInputROY PS Audio http://www.conversdigital.com This model is a connected audio module which supports the UPnP/DLNA standard specification. DirectStream DAC CDMCM-210-001 uuid:3A5BCA42-1F56-124A-BFEF-985E1B7E50DA http://www.conversdigital.com DMR-1.50 image/png 48 48 24 /images/small.png image/png 120 120 24 /images/large.png image/jpeg 48 48 24 /images/small.jpg image/jpeg 120 120 24 /images/large.jpg urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /service/RenderingControl1.xml /service/RenderingControl_control /service/RenderingControl_event urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /service/ConnectionManager1.xml /service/ConnectionManager_control /service/ConnectionManager_event urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /service/AVTransport1.xml /service/AVTransport_control /service/AVTransport_event http://192.168.0.12:38400Current device RootDevice description:
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:MediaRenderer:1 BridgeIIInputROY PS Audio http://www.conversdigital.com This model is a connected audio module which supports the UPnP/DLNA standard specification. DirectStream DAC CDMCM-210-001 uuid:3A5BCA42-1F56-124A-BFEF-985E1B7E50DA http://www.conversdigital.com DMR-1.50 image/png 48 48 24 /images/small.png image/png 120 120 24 /images/large.png image/jpeg 48 48 24 /images/small.jpg image/jpeg 120 120 24 /images/large.jpg urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /service/RenderingControl1.xml /service/RenderingControl_control /service/RenderingControl_event urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /service/ConnectionManager1.xml /service/ConnectionManager_control /service/ConnectionManager_event urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /service/AVTransport1.xml /service/AVTransport_control /service/AVTransport_event http://192.168.0.12:38400UPnP devices found : 2
Max. memory for audio buffers: 4026MB
Device #0: TV
What happens when you connect a USB cable direct to the PS Audio DAC?
Your pre-load buffer is 50% of your available RAM… try reducing it until you get good results…
The Microsoft Teams Audio application is still a wild-card…
What is you network system component architecture (router, switches, etc)?
Also the Direct Stream DAC is DSD capable via DoP 1.1…
Do you have the latest firmware installed in the PS Audio DAC?
Thanks for the ideas. I cant connect the iMac which runs my Audiravana to the DAC via USB given they are located in different rooms of my house.
Im not sure what you mean about the Microsoft Teams Audio app or what i can do about it.
I am running an Ethernet network with CAT 6 cables and 1gb Netgear switches. Roon works fine over this set up.
I have changed the Native DSD setting to DoP 1.1 but I cannot find where I change the DAC to a Stereo Only. It’s probably obvious but I have looked through the Audio section controls without finding it. Can you point me in the right direction.
I have the latest PS Audio DAC firmware loaded. Any help appreciated…
It’s a live teams streaming application… try removing it…
I don’t know why this is getting reported this way… the Direct Stream DAC is only two-channel… Yes? Could be something to do with UPnP… This is automatically set in Audirvana or in Audio MIDI Setup which should reflect the DAC as having two channels.
Try adding additional time for sample-rate change found in the DAC settings menu.
Hi,
I have changed the sample rate setting to 2 seconds and Radio Paradise has played without dropping out for over an hour. However, when playing an album from Qobuz, Tidal or my Local albums it stops after the first track. I have deleted Microsoft Teams, so the Audio component of the app should no longer be present.
I’m not sure what is happening now…
I see you have too many UPnP devices on your network(I’ve counted 3 from your logs). For correct results you need to allow only your source and destination UPnP servers running: the streamer and your dac, the rest should allow for UPnP turn off. Also please check your router under WAN settings and turn off UPnP there too. Therefore as solution I suggest you turn one of the devices off + router check for UPnP and disable.
Chances are this is your issue.
Thank you for the advice, I will give this a try.
I have turned off the router UPnP but can’t find out how to turn off the Sony TV one. I’m playing albums now and it is playing the full album and also Radio Paradise appears to be continuing to play. Fingers crossed the problem has gone since I way prefer Audirvāna to Roon for sound quality
This is great
Unfortunately this morning it is stopping again after playing one track on an album……it seems to have a mind of its own.
