Audirvana DSD iPurifier3
Hi to all,
I have a problem with a Mac mini (late 2012), playing DSD via DSDoP to a Topping E70, but only when my iPurifier3 is connected to the DAC.
When I connect the iPurifier3, the DAC shows PCM 170 kHz, and no sound is playing, When I connect it directly, without the iPurifier it works.
Also it works with the iPurifier3 connected with PCM files and when DSD is converted to PCM.
Playing my iPad with the purifier connected it manages to play DSD files and it shows it on the display.
When I bought the iPurifier3 it worked. I had to reinstall Audirvana, and after that it stoped working with the iPurifier 3.
I tried I thing all king of adjustments but I did not manage to make it work.
Has somebody an idea? I am really desperate. At ifi they also don’t have a clue.
Thank you for your help in advance,
Please post here your debug information so folks can help…
Hi @Kraftwerkmadrid,
Audirvana Studio 2.3.0 (20300)
macOS 10.15.7 with 16GB physical RAM
Connected account of : Super Sonidoloco
	Per track: OFF
AUTO: /Volumes/DJ TCKS/DSD
Library database path: /Users/robertfischer/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Tracks with no MBID: 230
Listening on 127.0.0.1 on port 49285
Max. memory for audio buffers: 256MB
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
Use max I/O buffer size: OFF
Topping E70
Model UID:E70:152A:8750
UID:AppleUSBAudioEngine:Topping:E70:1a131000:1
Device: 2ch Non-mixable linear PCM Interleaved 24bits little endian Signed Integer, 8 bytes per frame 176.4kHz
Active Sample Rate: 176.4kHz
Hog Mode is on
Selected device:E70
Manufacturer: Topping
Model name: Topping E70
Model UID: E70:152A:8750
UID: AppleUSBAudioEngine:Topping:E70:1a131000:1
USB Vendor ID: 0x152a
USB Product ID: 0x8750
ID 0x47
Audio buffer frame size : 53 to 4096 frames
Max volume alert: Disabled
Stream ID 0x48 2 channels starting at 1
30 virtual formats:
40 physical formats
Local devices found : 5
Device #0: ID 0x41 Salida integrada
Model UID: AppleHDA:88
Model name: Apple Inc. Salida integrada
Device #1: ID 0x47 E70
Device #2: ID 0x32 MJRecorder Device
Manufacturer: MJ Music Recorder contributors
Model UID: MJRecordDeviceModelUID
UID: MJRecordDevice
Model name: MJ Music Recorder contributors MJRecorder Device
Device #3: ID 0x2c Dispositivo agregado
Model UID: ~:AMS2_Aggregate:0
Model name: Apple Inc. Dispositivo agregado
Device #4: ID 0x2f Dispositivo de salida múltiple
Model UID: ~:AMS2_StackedOutput:0
Model name: Apple Inc. Dispositivo de salida múltiple
This is the info while it does NOT play the corresponding DSD256 File. At the DAC it shows 176khz PCM.
This is the same WITHOT the purifier3. And isound comes out: It shows 2.8Mhz DSD:
	Per track: OFF
Integer mode: ON
Topping E70
Hog Mode is on
Selected device:E70
UID: AppleUSBAudioEngine:Topping:E70:14400000:1
ID 0x50
Stream ID 0x51 2 channels starting at 1
30 virtual formats:
40 physical formats
Device #1: ID 0x50 E70
UID: MJRecordDevice
It seems the E70 is stuck at 176.4khz…
The E70 does not correctly reflect the DSD256 signal, it is reflecting DSD64…
…And isound comes out: It shows *2.8Mhz DSD
Try resetting the E70 to factory defaults and install the latest firmware… Also, when you get this sorted-out, I suggest increasing the playback buffer memory to 6GB.
But why only with iPurifier3 on? Without it it works perfectly!
Is it?.. The debug info you posted shows the active sample-rate as 176.4kHz in both cases… And you stated the DAC shows 2.8MHz DSD which is DSD64, when you stated that you were playing DSD256 which is 11.2MHz
Sorry it was in fact a dsd64 file.
It still does not work:(
Hi to all. A storage thing happened. I tried to change DSDoPCM from version 1.1 to 1.0 and suddenly it worked. The storage thing is that I changed it back and then it still worked. So the solution is to change it to 1.0, play something and then put the setting back. Why could this be?
In any can thank you all for your help!
It was stuck… :sunglasses:
