Can I use the EQ-Values from REW (Room EQ Wizard) in Audirvana or is the result different? If yes, an import feature would be nice improvement.
Not knowing anything about your use of REW and the EQ filter types you may have generated, my guess would be that their may be a difference…
However, I believe you could use REW’s Generic Configurable PEQ to match Audirvana’s EQ setting requirements… Although I have not tried to do this for Audirvana…
Hi Densagined Yes, you can use EQ values from REW in Audirvana.
