Audirvana failing together with the ASIO Audiolense convolver
Does anyone know what to do about the Audirvana failing together with the ASIO Audiolense convolver? In the latest version of Audirvana, it is completely hopeless to start the program with Audiolense Convolver. Other players work fine.
Fails with: UnhandledException: External component has thrown an exception.
This is the log:
2024-10-10 23:02:58.897 [critical]: ============= UnhandledException =============
System.Runtime.InteropServices.SEHException (0x80004005): External component has thrown an exception.
at Audirvana.Controller.Popup.AudioSettingsController.selectAudioDevice(AudioSettingsController*, AudioDevice*)
at Audirvana.View.AudioSettingsView.selectAudioDevice(Object parameter)
at Audirvana.DelegateCommand.Execute(Object obj)
at System.Windows.Controls.MenuItem.InvokeClickAfterRender(Object arg)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
Hi @Geir,
Do you get a Audirvāna dmp file on your desktop folder? If so, can you send it at [email protected]?
Hello
Audiolense has released a new version of the convolver. 1.8. Now Audirvana doesn’t even try to pick up the ASIO interface. No error message at all. Foobar2000 and JRiver are ok as before.
