Audirvana keeps closing
Have latest version of Audrivana Studio on windows 10 pc.The program keeps closing.
Any other places to go for support ?
Jason, please post your debug report here so that the community can see if anything stands out as a potential problem. Otherwise you will have to wait until @Antoine gets back on duty. support@audirvana.com is the other option.
A little more detail would be helpful as well.
Hi @Jason_Pasosky,
Can you send more information about your issue? When do you encounter this issue? Is it when you open Audirvāna Studio?
It happens most often if I stop music and select other music.And on occasion will close when music is playing.
We would like to check your issue, can you send us your audirvana.dmp and audirvana.log file at support@audirvana.com ?
to show AppData folder:
