Audirvana Linux does not connect to Qobuz
I needed to re-install Audirvana Studio Linux as I was updating Linux Mint to 22 “Wilma”. All went well, except Audirvana (latest version 2.8.2.2) does not connect to Qobuz. Audirvana seems to be on-line, and yet, it does not connect to Qobuz. If I try to connect, it gives me an error. Also the Radio button is inactive. My Qobuz account is active, so it should connect to it, shouldn’t it?
Any bright ideas from the Linuxers?
Thanks!
I’m sorry, I reacted a bit early. The problem was with Qobuz itself. Roon Linux showed the same: unable to stream from Qobuz, but in the meantime both stream oerfectly well from Qobuz.
Hi @Sailor,
Do yous till have your issue to connect to Qobuz in the Linux version?
Hello Antoine
Thanks for getting back to me!
Indeed, the problem seems to be that Audirvāna prefetentially stays off-line, while only occasionally it connects online and allows connection to Qobuz and webradio. No idea why.
Br, Paul
If you take a look at the logs, do you see something spetial?
You can see them by clicking the 'Open Log Folder’ button in Audirvāna settings under My account section
I‘ll do that when I‘m back (next Monay). Right now I am enjoying my holidays in Hungary :grinning:
Still unable to connect to Qobuz with Audirvana Linux (running on a MacBook Air, Ubuntu LTMS 24.04). Here’s the debug info. It tells me that network status is unavailable, but my WiFi runs perfectly fine and the computer is logged into the network.
Bitte schreiben Sie nichts unter diese Zeile
Audirvana Studio 2.8.2.2
Linux 6.8.0-41-generic x86_64 with 3.7GB physical RAM
OFFLINE MODE
Connected account of :
Status: unavailable
AUTO: /mnt/Music
Library database path: /home/audirvana/.local/share/audirvana/AudirvanaDatabase.sqlite
Tracks with no MBID: 0
Listening on on port 34381
Font size: regular
Language: Systemsprache
Meine Musik
Radios
Podcasts
Streaming
Lokal
Startup view: Meine Musik: Alben
Number of paired remotes: 2
Max. memory for audio buffers: 1914MB
Local Audio Engine: Linux ALSA library 1.2.11
Advanced Linux Sound Architecture Driver Version k6.8.0-41-generic.
Devialet USB Audio 2.0
Model UID:Devialet USB Audio 2.0
UID:Devialet Devialet USB Audio 2.0 at usb-0000:00:1a.7-1.3, high speed
Device: 2ch 32bits Integer, 8 bytes per frame 96kHz
Active Sample Rate: 96kHz
Selected device:Devialet USB Audio 2.0
Manufacturer:
Model name: Devialet USB Audio 2.0
Model UID: Devialet USB Audio 2.0
UID: Devialet Devialet USB Audio 2.0 at usb-0000:00:1a.7-1.3, high speed
USB Vendor ID: 0x28d4
USB Product ID: 0x0008
Simple stereo device: No
Device #0: HDA Intel PCH
Manufacturer:
Model UID: HDA Intel PCH
UID: HDA Intel PCH at 0xa0600000 irq 33
Model name: HDA Intel PCH
Device #1: Devialet USB Audio 2.0
Manufacturer:
UPnP not started
Chromecast not started
I have no clue why, but when I hit ,Disconnect’ in the settings ‘My Account’, my computer immediately connects to Qobuz and everything works fine. Could it be that my Mac tries to connect to another Mac in my home and gets confused? I have no idea, but whenever it is in local mode, hitting the disconnect button solves the problem!
