Hello, greetings
Could you help me with the following problem:
I run Audirvana Studio on an Intel NUC 7 (Windows 10) … the problem is that it doesn’t load each song properly in Tidal … it does so very slowly … and that causes the sound to cut out constantly … my connection is good … 190 mbps … I have granted permissions to Audirvana through Windows Firewall and everything remains the same … I don’t use a paid antivirus, I use the Windows one … any help is appreciated, greetings.
How much internal memory is Audirvana using? You can see that in Audirvana (the buffer size)
Hello, I answer you this way … you are right ! … I had the default buffer size … I raised it and the problem is over, thank you ! Greetings
