Hi Damien,
Here you go
Audirvana 3.5.44
SW volume control: ON
Sync list: 0 folders
Library database path: C:\Users\Scrat\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 4972MB
Local Audio Engine:ASIO 2 driver version 1110
Khadas Tone
Model UID:Khadas Tone
UID:Khadas Tone
Khadas Tone Manufacturer:
Model UID:Khadas Tone UID:Khadas Tone
2822400
5644800
11289600
22579200
DSD capability: Raw DSD (MSB)
Device #0: JPLAY Driver Manufacturer: Model UID: JPLAY Driver UID: JPLAY Driver
Device #1: Khadas Tone Manufacturer: Model UID: Khadas Tone UID: Khadas Tone
UPnP devices found : 2
Device #0[LG] webOS TV OLED55C6V UID: uuid:5b66a173-cbfd-7d03-8a6b-3e8e0083fd34 Location: http://192.168.0.155:1720/
Device #1JPLAY FEMTO UID: uuid:JPLAY192.168.0.139-MediaRenderer Location: http://192.168.0.139:48167/JPLAY192.168.0.139-MediaRenderer/Upnp/device.xml
Le ven. 26 févr. 2021 à 10:02, Damien3 via Audirvana <noreply@community.audirvana.com> a écrit :
Damien3
February 26
Note: By clicking on the Debug Info button, Audirvana automatically copies all its content, all you have to do is paste it in response to this mesage
Visit Topic to respond.
To unsubscribe from these emails, click here.
