Would you tell me where and how to get version 2.5.12?
Thanks a lot.
I am using a file that I previously downloaded from the Audirvana site. At the time I downloaded it (May 6th of this year), it was the latest version.
Apologies, should pay attention… I 'm on Mac, no X for me.
I doubt that they are debugging and releasing them properly.The bug is obvious as soon as you launch it.If you can’t deal with the bugs right away, you should revert to 2.5.13.
I sent an email to audirvana on 2024/09/19 to request the 2.5.13 version, but did not receive a reply.
Hi everyone,
It seems this issue only affects Japanese users of Audirvāna Origin, as far as I can see by email and on the forum.
I’m trying to reproduce your issue on my side as I write this post; I will post more information on the progress of this issue in the following days.
Hi Antoine,
Now, I can listen to my music library again.
Thanks a lot.
I hope you will find the reason and fix it to provide a new version soon.
Best wishes,
TT
Hi, Everyone,
I’ve downgraded to 2.5.13, now the directories scan seems works fine at the moment, I am re-scaning my all folders. I have 5 TB albums and songs in the folders. I thought it was my PC’s problem, I restored my whole system by dates one by one. Jesus, Audirvana, your bug wasted my time so much! Damn you! I erased my all playlists and data records sqlite file. Now I have to rebuild all my music database. Your bug kills me.
I’m a Korean user, though I have the same issue. I’m looking forward to a fixed version soon. Meanwhile, I’m going to use the older version. Thanks.
Hi, everyone; I have big news for you: we have been able to fix the issue!
If you want to try it out, you can use the link below:
https://audirvana-my.sharepoint.com/:f:/p/antoine/EkHaCab0Ki9Ohgeor8lLahcB_cwtq2z6gHDREJJylY-2jQ
Thanks. I’ve just tried it and it seems to work fine.
AUDIRVANA ORGIN 2.5.15
The sync still can not progress.
- ‘synchronisation in progress’ contines;
- clicking the X in the top right corner to exit the app doesn’t work.
I have no choice but to continue using AUDIRVANA ORGIN 2.5.13
TAIWAN
I’ve been looking forward to this day. Everything is working smoothly. Thank you!
Hi Antoine,
I have the same problem.
And I’m also Japanese.
Thank you.
Hi, Antoine,
I downloaded it and updated to Origin 2.5.15.0.
The problem has been resolved.
When I launch the app, the sync starts automatically and completes successfully.
I also tried a manual sync from the settings page and that also completes successfully.
I have found no new serious issues with this update until now.
I’m looking forward to the official release!
Thank you so much!
