Audirvana Origin 2.6.0 does not play multichannel files to Yamaha RX-V685 via UPnP.
Audirvana starts playing but doesn’t send audio signal to Yamaha AV-receiver.
What might be the reason?
Audirvana Origin 2.6.0 (20600)
macOS 12.7.6 x86_64 with 16GB physical RAM
Connected account of : Kari Puikkonen
DSP NOT ACTIVE
r8brain to DSD256 with filter type B 7th order
Replay Gain: by album
Sync list: 2 folders
AUTO: /Users/karipu/Documents/Uudet/_Musiikki
AUTO: /Volumes/Musiikki/
Sync folders at startup: YES
Sort and display order: en
Library database path: /Users/karipu/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 60457
Font size: large
My Music
Library
Startup view: My Playlists
Use Apple Remote: yes
Number of paired remotes: 2
Screen saver disabled: no
Active method: UPnP
Wi-Fi
Preferred device: [UPnP] RX-V685 Model UID:Yamaha Corporation RX-V685 UID:uuid:9ab0c000-f668-11de-9976-4c1b8625ff1a
Currently playing to UPnP device at 32 bits 2822.4kHz
Selected device:RX-V685
Manufacturer: Yamaha Corporation
Model name: RX-V685
Model UID: Yamaha Corporation RX-V685
UID: uuid:9ab0c000-f668-11de-9976-4c1b8625ff1a
UPnP device at http://192.168.1.100:49154/MediaRenderer/desc.xml
ID 0x0
Volume control: Yes
Raw DSD (msb)
Multichannel: 6 channels
Channel 2 unused
Channel 3 unused
Channel 4 unused
Channel 5 unused
UPnP set capabilities
Maximum PCM bitdepth set: 32
Maximum DSD rate set: DSD256
Number of channels: 6
Avoid RAW PCM streams: Yes
Unwanted playback stop workaround: Yes
http-get::audio/L16;channels=2;rate=44100:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=1;rate=44100:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=2;rate=48000:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=1;rate=48000:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=2;rate=32000:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=1;rate=32000:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=2;rate=88200:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=1;rate=88200:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=2;rate=96000:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=1;rate=96000:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=2;rate=64000:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=1;rate=64000:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=2;rate=22050:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=1;rate=22050:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=2;rate=24000:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=1;rate=24000:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=2;rate=16000:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=1;rate=16000:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=2;rate=11025:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=1;rate=11025:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=2;rate=12000:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=1;rate=12000:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=2;rate=8000:DLNA.ORG_PN=LPCM
http-get::audio/L16;channels=1;rate=8000:DLNA.ORG_PN=LPCM
http-get::audio/x-ms-wma:DLNA.ORG_PN=WMDRM_WMABASE
http-get::audio/x-ms-wma:DLNA.ORG_PN=WMDRM_WMAFULL
http-get::audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS_192
http-get::audio/mp4:DLNA.ORG_PN=AAC_ISO_192
http-get::audio/3gpp:DLNA.ORG_PN=AAC_ISO_192
http-get::audio/x-ms-wma:*
http-get::audio/x-flac:
http-get::audio/x-mpeg:
http-get::audio/x-aac:
http-get::audio/x-mp3:
http-get::audio/x-mp4:
http-get::audio/x-mpg:
http-get::audio/x-wav:
http-get::audio/aacp:
http-get::audio/aiff:
http-get::audio/x-aiff:
http-get::audio/flac:
http-get::audio/mpeg:
http-get::audio/aac:
http-get::audio/m4a:
http-get::audio/mp3:
http-get::audio/dsd:
http-get::audio/x-dsd:
http-get::audio/x-dsf:
http-get::audio/x-dff:
http-get::audio/wav:
DLNA 1.5: Yes
Native Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
Volume Control: scalar
Number of active channels: 6, in 1 stream(s)
42 virtual formats:
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 44.1kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 88.2kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 176.4kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 48kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 96kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 192kHz finite length
2 ch Non-mixable linear PCM Interleaved 8 little endian Signed Integer 11289.6kHz finite length
6 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 44.1kHz finite length
6 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 44.1kHz finite length
6 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 44.1kHz finite length
6 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 88.2kHz finite length
6 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 88.2kHz finite length
6 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 88.2kHz finite length
6 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 176.4kHz finite length
6 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 176.4kHz finite length
6 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 176.4kHz finite length
6 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 48kHz finite length
6 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 48kHz finite length
6 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 48kHz finite length
6 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 96kHz finite length
6 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 96kHz finite length
6 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 96kHz finite length
6 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 192kHz finite length
6 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 192kHz finite length
6 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 192kHz finite length
6 ch Non-mixable linear PCM Interleaved 8 little endian Signed Integer 2822.4kHz finite length
6 ch Non-mixable linear PCM Interleaved 8 little endian Signed Integer 5644.8kHz finite length
6 ch Non-mixable linear PCM Interleaved 8 little endian Signed Integer 11289.6kHz finite length
0 physical formats
NrTracks: 1
MediaDuration: 0:05:06
CurrentURI: http://192.168.1.108:49152/audirvana/audio_f_47.dff
CurrentURIMetadata: dc:titleZimbabwe</dc:title> dc:creatorThe Coryells</dc:creator> upnp:artistThe Coryells</upnp:artist> upnp:genreJazz</upnp:genre> upnp:albumArtURIhttp://192.168.1.108:49152/audirvana/artwork_1_47.jpg</upnp:albumArtURI> upnp:albumThe Coryells</upnp:album> upnp:originalTrackNumber6</upnp:originalTrackNumber> upnp:classobject.item.audioItem.musicTrack</upnp:class> http://192.168.1.108:49152/audirvana/audio_f_47.dff
nextURI: http://192.168.1.108:49152/audirvana/audio_f_49.dff
nextURIMetadata: dc:titleLow-Lee-Tah</dc:title> dc:creatorThe Coryells</dc:creator> upnp:artistThe Coryells</upnp:artist> upnp:genreJazz</upnp:genre> upnp:albumArtURIhttp://192.168.1.108:49152/audirvana/artwork_0_49.jpg</upnp:albumArtURI> upnp:albumThe Coryells</upnp:album> upnp:originalTrackNumber7</upnp:originalTrackNumber> upnp:classobject.item.audioItem.musicTrack</upnp:class> http://192.168.1.108:49152/audirvana/audio_f_49.dff
PlayMedium: NETWORK
Current transport actions:
Stop,Play,Seek,X_DLNA_SeekTime
<?xml version="1.0"?> 1 0 DMR-1.50 urn:schemas-upnp-org:device:MediaRenderer:1 RX-V685 Yamaha Corporation http://www.yamaha.com/ AV Receiver RX-V685 V685 http://www.yamaha.com/ 00F0D513 uuid:9ab0c000-f668-11de-9976-4c1b8625ff1a image/jpeg 48 48 24 /Icons/48x48.jpg image/jpeg 120 120 24 /Icons/120x120.jpg image/png 48 48 24 /Icons/48x48.png image/png 120 120 24 /Icons/120x120.png urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /AVTransport/desc.xml /AVTransport/ctrl /AVTransport/event urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /RenderingControl/desc.xml /RenderingControl/ctrl /RenderingControl/event urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /ConnectionManager/desc.xml /ConnectionManager/ctrl /ConnectionManager/event http://192.168.1.100/ http://192.168.1.100:80/ urn:schemas-yamaha-com:service:X_YamahaRemoteControl:1 /YamahaRemoteControl/ctrl /YamahaRemoteControl/desc.xml urn:schemas-yamaha-com:service:X_YamahaExtendedControl:1 /YamahaExtendedControl/v1/ 2100Current device RootDevice description:
<?xml version="1.0"?> 1 0 DMR-1.50 urn:schemas-upnp-org:device:MediaRenderer:1 RX-V685 Yamaha Corporation http://www.yamaha.com/ AV Receiver RX-V685 V685 http://www.yamaha.com/ 00F0D513 uuid:9ab0c000-f668-11de-9976-4c1b8625ff1a image/jpeg 48 48 24 /Icons/48x48.jpg image/jpeg 120 120 24 /Icons/120x120.jpg image/png 48 48 24 /Icons/48x48.png image/png 120 120 24 /Icons/120x120.png urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /AVTransport/desc.xml /AVTransport/ctrl /AVTransport/event urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /RenderingControl/desc.xml /RenderingControl/ctrl /RenderingControl/event urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /ConnectionManager/desc.xml /ConnectionManager/ctrl /ConnectionManager/event http://192.168.1.100/ http://192.168.1.100:80/ urn:schemas-yamaha-com:service:X_YamahaRemoteControl:1 /YamahaRemoteControl/ctrl /YamahaRemoteControl/desc.xml urn:schemas-yamaha-com:service:X_YamahaExtendedControl:1 /YamahaExtendedControl/v1/ 2100UPnP devices found : 1
Device #0: ID 0x0 : RX-V685
Location: http://192.168.1.100:49154/MediaRenderer/desc.xml
Model name: RX-V685
Max. memory for audio buffers: 8012MB
Local Audio Engine: CoreAudio
Device #0: ID 0x3b Built-in Output
Model UID: AppleHDA:130
UID: AppleHDAEngineOutput:1F,3,0,1,2:0
Device #1: ID 0x2b Microsoft Teams Audio
Manufacturer: Microsoft Corp.
