Audirvana Origin overjumps tracks in Music Mode
I just installed my older headphone-amp to use it with my apple music library. Everything works fine and it sounds great!
Except: jumping to the next track either on the apple music button or the audirvana one jumps NOT to the next track. It overjumps always the next one (example: listening to track 1, push the “next track” button audirvana plays track 3, and so on.
BUT: Only forewards! Backwards it jumps to the right track!
Using Apple Musik without Audirvana jumping is fine.
Using the cd-library in Audirvana (NO Music Mode) - everything ist fine.
Whats wrong?
Debug-Info:
Audirvana Origin 2.5.19 (20520)
macOS Version 15.2 (Build 24C101) ARM64 with 16GB physical RAM
Connected account of : Andi xxxx
Local network access: allowed
AUTO: /Users/macbookandi/Documents/audirvana bibliothek
iTunes/Music library synchronization: last synchronized on Sat Jan 25 16:27:50 2025
Sort and display order: de
Library database path: /Users/macbookandi/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on on port 61961
Font size: regular
Language: Systemsprache
Meine Musik
Bibliothek
Startup view: Meine Musik: Alben
Use Apple Remote: yes
Number of paired remotes: 1
Screen saver disabled: no
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
TEAC Corporation TEAC USB AUDIO DEVICE
Model UID:TEAC USB AUDIO DEVICE:0644:8043
UID:AppleUSBAudioEngine:TEAC Corporation:UD-503:3120000:1
Device: 2ch Non-mixable linear PCM Interleaved 32bits little endian Signed Integer, 8 bytes per frame 44.1kHz
Hog Mode is on
Selected device:TEAC USB AUDIO DEVICE
Manufacturer: TEAC Corporation
Model name: TEAC Corporation TEAC USB AUDIO DEVICE
Model UID: TEAC USB AUDIO DEVICE:0644:8043
UID: AppleUSBAudioEngine:TEAC Corporation:UD-503:3120000:1
USB Vendor ID: 0x0644
USB Product ID: 0x8043
ID 0x7f
9 available sample rates up to 705600Hz
DSD via PCM 1.1
Stream ID 0x80 2 channels starting at 1
36 virtual formats:
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 705.6kHz
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 384kHz
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 352.8kHz
54 physical formats
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 705.6kHz
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 384kHz
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 352.8kHz
Local devices found : 3
Device #0: ID 0x78 Studio Display-Lautsprecher
Model UID: Studio Display Audio Control:05AC:1114
UID: AppleUSBAudioEngine:Apple Inc.:Studio Display:00008030-001218503EF0802E:8,9
USB Vendor ID: 0x05ac
USB Product ID: 0x1114
Model name: Apple Inc. Studio Display-Lautsprecher
Device #1: ID 0x7f TEAC USB AUDIO DEVICE
Device #2: ID 0x67 MacBook Pro-Lautsprecher
Model UID: Speaker
UID: BuiltInSpeakerDevice
Model name: Apple Inc. MacBook Pro-Lautsprecher
Selected Network interface: WLAN
WLAN
Hi @links,
to make sure we are talking about the same thing, do you have Music integrated mode activated when you have your behavior?
Hi Antoine.
Exactly: It ONLY happens using the “Music Integrated” Mode.
Using Apple Music solo, without Audirvana - everything is OK.
Using the Apple Music-Library imported in Audirvana - everything is OK.
AND only skipping forward!
hi there.
nobody has a solution for that?
i tried Origin on an other computer - same behaviour!
and now the best thing: i opened the old audirvana 3.5 and switched to “Music Mode” - jumping to the next track works fine!
whats wrong with Origin?
