Why does this happen? It’s worthless now.
Settings: The app scans my library every time at startup so I presume the database is always updated.
Help much appreciated.
Hello @HansL, can you amke a screenshot of your settings section of your Remote app and a screenshot of the album you selected?
Hi Damien, I replyed to your mail but it bounced. In the meanwhile I updated the app, deleted the sql database and recreated the library. Problem seems to be gone now. Hope it stays so, thanks for the good work regards /Hans
