I’m having a lot of trouble with Audirvana Plus. If i leave the programme running often it locks up beach ball on computer and "No Response"in activity Monitor, I more often than not have to restart or force quit Audirvana. On reload there is a variable number of albums and tracks loaded I have at least 1440 albums but loading to this level takes several hours if it even loads them all.
MAC MINI mid 2010 El Capitain 10.11.6. Audirvana Plus 3.2.19 (3703). Netgear Ready NAS 104.
OK my system has the music files on a NAS Netgear 104, 2 x4TB drives, files are a mix AIF, FLAC and WAV majority 16/44, some hi-res 24/96 or 24/128 a few DSD.Audirvana is pointed to the files on the NAS in preferences.
I’ll look into updating to 3.5. Just looked at my setup. 3.5 is not offered as an option it says 3.2.19 is current option. Do I assume 3.5 does not run on OSX El Capitain 10.11.6? My iMac has already updated to 3.5 that is running 10.14.6 Mojave.
I’m still getting inconsistent totals, but I’m investigating and trying to make a new definitive file for my music.
One thing I have noticed is that v3.5.33(3503) on MacMini opens Audirvana plus in stead of v3.5 when I try to log on to TIDAL.
I deleted the old versions and have made a new music source file on my NAS Netgear 104.
Audirvana is downloading from this new folder and the albums aren’t being seen in the correct order.
I’ll not answer further for a while I am pointing my iMac to the new folder now and I will wait until that has finished and see how that ends up on that computer.
I will contact you later.
Hi, still getting inconsistencies, not sure where to start. I have 2 computers running Audirvana although only 1 will be used for music. iMac 2015 running OSX 10.14 Mojave and Audirvana 3.5 the other is MacMini 2010 running OSX 10.11 El Capitan and 3.5. I was getting inconsistent numbers for the amount of data loaded from my music file they are still not exactly the same but within 8 albums of each other.
Main queries seem to be where are these .iql files? I can’t see them on either machine I’m assuming they are some sort os local storage as Audirvana still seems to work even if I take away a location for the music file. Is there anyway of resetting/clearing the system and do a fresh load? I am still getting double entries for some albums.
Other point is where has batch edit gone? Editing leaves a lot to be desired, why does the artist list not just have a section of artist shown against each album, having every single artist for every track is as real mess when you are editing the metadata in such a small window.
Where is the user manual for 3.5?
I am prepared for these answers to be my fault but I can’t at the moment see where i am going wrong.
